Topic: started on the subframe connectors (Read 836 times)
Very nice work for a first attempt.
 .....good job, seems well thought out too. I would rather have a little overkill than not enough.
OUTSTANDING!! good work
Scampin
Wow! That looks awesome!
Nice work!
looks real good.
thanks
i like those saw horse legs too.
Lol hope you don't mind but I'm "borrowing" the pics for examples when I go and do mine  Good work
Nice work, they look good.
Nice job dude!
Carter
mopardude318
those look awesome! nice work!
1970 Dodge Dart, 408 sb, eddy heads, 4 spd, alterktion, 8 3/4
Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax. - David Charles Gedraitis
Nice looking work ...
Thanks guys. I'm trying to figure out what I'm going to do for an e-brake. Do you think I can just weld a piece of angle iron on the bottom of the drivers side subframe connector and drill the appropriate size hole for it? That way the cable would run under the connector. Or should I just use it's stock location and drill a hole in the subframe connector for the cable to go through? Any ideas?
there is usually enough room to dril a new hole along the old one so it will be outside the frame connector ... or if the only part of of the frame connector that interfers is the front flange then drill that puppy out and letr' rip
I ran my cable under the connector. Just cut a piece of round tube in half and tack it to the bottom to capture the cable where you want it.
urchinhead
Wow! Those pictures make we want to take the welder out!
WRAITH
Soooo,... now I think I'll hafta turn mine 90 Degrees. Thanx buddy! Nice work by the way.
WRAITH
'67 Dart GT Low Deck 400 Hemi 4 Speed 8 3/4"
HemiDoug
For the e-brake, I made a new set of holes farther outboard and above the flange on the frame connector. The hole is bigger on the front side of the crossmember than the rear, and the rear hole has to be the right size to capture the e-brake bushing. Just duplicate the hole sizes, and make sure they are in line! Great looking installation!
