September 07, 2008, 09:03:31 PM
| | |-+  10" backing plates?? All Same??
Author Topic: 10" backing plates?? All Same??  (Read 607 times)
suregrip391
« on: February 18, 2007, 10:14:33 AM »
Im thinking of a change from small bolt pattern to large bolt pattern on my car. I may buy a set of the Yukon axles for my A-body. Can I use my stock 10 x 1 3/4" shoe backing plates? Was wondering if they were the same as the 10 x 2.5" 8 3/4 rearend backing plates.....Huh??  brain fart
abqdart
72 Swinger 394/727/8.75
Re: 10" backing plates?? All Same??
« Reply #1 on: February 18, 2007, 11:24:59 AM »
I think the backing plates will work? I put on some of those C-body brakes with the big cooloing fins.....might change to B-body....would drop a few pounds.... Dunno I just woke up....
Rio Rancho N.M 87144
suregrip391
« Reply #2 on: February 18, 2007, 12:15:20 PM »
Someone told me they were different, and I wanted to know how to tell the difference in them??? Anyone out there have any experience with this??
Allentown, PA
« Reply #3 on: February 18, 2007, 04:07:20 PM »
the 10 X 1 3/4 plates are different from the 10 X 2.5" plates ... .the offset of the axle remains the same no matter what brake setup you have, they changed the offset depth of the backing plate to match the drums.  the spreader bar for the E brake setup is also different between the two.  hit the junkyard and grab all the stuff for a 10x 2.5 setup ...
duster
suregrip391
« Reply #4 on: February 18, 2007, 04:27:32 PM »
Thanks 68_Val_Sedan !!!  Appreciate the info.  thank you
abqdart
« Reply #5 on: February 18, 2007, 04:35:04 PM »
that makes sense. I guess they turn back in toward the center section to allow wider brakes??maybe....
Allentown, PA
« Reply #6 on: February 18, 2007, 06:10:54 PM »
correct the wider the drum the closer the backing is to the center section
bbd sign
gregpurcell
« Reply #7 on: February 18, 2007, 06:13:09 PM »
Sorry guys, but this is a "BEEN THERE/DONE THAT" thing for me!!
THE A BODY 8 3/4 10 inch BACKING PLATES ARE DIFFERENT FOR SMALL BOLT PATTERN AXLES!!!!
It works like this: The OFFSET on an A body axle is different. (I think 1/4 inch).
If you use REDRILLED A BODY SMALL BOLT AXLES, you HAVE TO USE the ORIGINAL backing plates and redrill the drums. You CANNOT use B/E backing plates with redrilled A body axles.
If you CUT DOWN B/C body axles or buy aftermarket version duplicates, then you CAN use the B/E body backing plates.
Just remember: A body axles, A body plates
B/C/E body axles, B/C/E body plates.
Good Luck!
suregrip391
« Reply #8 on: February 18, 2007, 06:16:20 PM »
What does one use when using an A-body axle made by Yukon??  Its an aftermarket axle, 28" like the original but uses the big bolt pattern. I would need big bolt pattern drums, so I assume I would need different backing plates correct??....Cant use my originals is what I understand??
gregpurcell
« Reply #9 on: February 18, 2007, 06:25:15 PM »
I'm not real familiar with the Yukons, but the Mosers are all the same offset as the B/C/E body unless Mosier cuts and redrills your existing SBP A body axles. You might ask the Yukon people when you order. I'm certain they are familiar with the offset difference.
abqdart
« Reply #10 on: February 18, 2007, 07:05:06 PM »
I have Yukon axles and I used the brakes off of a 76 C-body. So, my guess would be get rid of the SBP A-body brakes and run the B/C body stuff if you want drums. I did see a truck in the yard I think it was a mid 70's half ton with what looked like B-Body brakes too.
Allentown, PA
« Reply #11 on: February 18, 2007, 08:06:39 PM »
The Yukon A body axles have the same offset.   You can use the C boat brake stuff on the A body housing with the new Yukon Axles ... done it several times ...  4 speed
duster
suregrip391
« Reply #12 on: February 18, 2007, 08:09:18 PM »
not many good yards around me here, anyone have any 10 x 2.5" stuff that will work on my 8 3/4 ?? backing plates and drums etcc....complete??..That they want to sell?..I can get new hardware so Im not worried about wheel cylinders and springs and things......PM me or email suregrip391@adelphia.net with a pic and price? Shipped to 14304 Ny Thanks.
urchinhead
San Francisco, CA
« Reply #13 on: February 18, 2007, 11:06:16 PM »
Suregrip - if you end up getting the 10 x 2.5" brakes, I'd like to buy the ebrake stuff from your 10 x 1.75" brakes. I can't find those parts anywhere! Please let me know.  Undecided
gregpurcell
« Reply #14 on: February 19, 2007, 12:55:11 AM »
I have the e-brake cables included in this auction $9.99 opening bid with no takers yet:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=013&sspagename=STRK%3AMESE%3AIT&viewitem=&item=230092108438&rd=1,1
urchinhead
San Francisco, CA
« Reply #15 on: February 19, 2007, 01:00:53 AM »
You're picture/link didn't pop up. Is this the auction Greg?
http://cgi.ebay.com/ebaymotors/Mopar-Ply-Dodge-7-1-4-rear-10-inch-Brake-Backing-Plates_W0QQitemZ230092108438QQihZ013QQcategoryZ34199QQrdZ1QQcmdZViewItem
Can I just buy those off you for a set price? All I need are the spreaders/struts and levers/actuators from each side. Thanks,
        Mike
abqdart
« Reply #16 on: February 19, 2007, 01:21:42 AM »
Suregrip,
 I make atleast a run a week to the wreckers. We have a few good pick a parts here. I should be able to find you something. I will be going there probably thursday or Friday. They want $50 for complete sets of rear drums. You would be responsible for the parts, S+H. You can Email me at pavedarrin@yahoo.com if you want to do this. that also includes whatever ebrake cable is attached. let me know
Darrin
gregpurcell
« Reply #17 on: February 19, 2007, 09:55:47 PM »
If the auction ends without a bid, we'll work something out. I'm just gonna scrap em if they don't sell.
urchinhead
San Francisco, CA
« Reply #18 on: February 19, 2007, 11:44:09 PM »
Sounds good Greg. Hopefully between you and Suregrip, I'll get those parts I've been dreaming about.  Undecided
