September 08, 2008, 07:02:05 AM
| | |-+  Routing brake line from master cylinder to line lock
Author Topic: Routing brake line from master cylinder to line lock  (Read 383 times)
5258
bigblockdart.com
« on: February 19, 2007, 10:00:22 PM »
Re-doing my brakes lines this off season while replacing line lock, currently line lock is located on inside of drivers frame rail, my only concern with that layout is that now since going to chassis headers (mad dog's) the line lock and brake lines will be to close to the headers. So I want to re-route the intire system.  Duster is a drag only car fenderwells have been cut so i was thinking of mounting down low behing driver's side tire.
Does anyone have any pics of there set up or helping info.
Thanks
5258
5258 Performance  Shelbyville, Tennessee "Where the MOPAR factory built and race ready hotrods live again"
cu440da
Saint Paul, MN
Re: Routing brake line from master cylinder to line lock
« Reply #1 on: February 20, 2007, 07:23:04 PM »
Mounted mine right next to the master cylinder.
'67 Notchback- 12.85 @ 109mph
W2-408
Leduc Alberta Canada
« Reply #2 on: February 21, 2007, 12:05:34 AM »
Here's mine
1973 Duster 360/904,  11.34 @ 119.15mph...... for now, and still driven almost daily
W2-408
« Reply #3 on: February 21, 2007, 12:07:12 AM »
Sorry, didn't notice you mentioned fenderwell headers hammer
chryco
« Reply #4 on: February 21, 2007, 07:21:02 AM »
Build a heat shield !
Hemi Darts Rule !!!!!
thebankerstoy
« Reply #5 on: February 23, 2007, 11:59:23 AM »
On my 66 Coronet, I wanted to keep the line-lock as close to the brake booster as I could, to keep the fluid lines as short as possible.
Richard
5258
bigblockdart.com
« Reply #6 on: February 23, 2007, 05:49:04 PM »
Hey chryo,
That radiator mount and overflow mounting braket is sweet, Can you get me some more up close pics of that, project for tommorrow is mounting radiator and overflow tank, I have a fiberglass front clip so your set up would work great with mine also.
Thanks
5258
jacks62440
« Reply #7 on: March 05, 2007, 09:17:16 PM »
Not Plumbed Yet, But there it is.
Jack
5258
bigblockdart.com
« Reply #8 on: March 05, 2007, 09:23:17 PM »
Got it routed this weekend, thanks for everyone's input.
duster
bbd sign
5258
oldkimmer
« Reply #9 on: March 06, 2007, 07:02:30 AM »
If u want to run at a NHRA track to pass tech u will have to T into each front brake line after the prop/ splitter valve....This was a rule change for 05........kim.......
