Topic: Leaf Springs (Read 619 times)
moparwedden
 How Much Of A Curve Should The Leaf Springs Be. Mine Has Little Curve On Weight.
Blvedere
Never gave it much thought on cars, but on large trucks ,the springs could not be "gull winged" when loaded. That is the center higher than the shackle ends.
notenuffcash
I have a 72 dart, the leaf springs are flat, with weight. It is not going to hurt anything, its all in how you want your ride to sit. The car should corner better with a flat/flatter spring. Personally, I like the rear to sit a bit higher, I am looking for a set of leafs that will do that. I dont know what effect it will have on your traction. Probably not help it any. If you do get a new set of springs, let us/me know how it sits, and which springs you got, thanks.
We used to laugh at Grandpa when he'd head off and go fishing. But we wouldn't be laughing that evening when he'd come back with some whore he picked up in town.
Jack Handy
moparwedden
I to Want My Back End Too Sit A Little Higher, Can I Do This With A Set Of Air Shocks.
moparrr07
just make a longer shackle for it with some flat stock and grade 8 bolts, less than $15
btw, shocks don't effect ride hight at all
50% custom interior
mopowers
Shocks can raise ride height if you install air shocks and pump the hell out of them. You'll be riding in the clouds. Thats about as jury rigged as it gets though... Next to long ass rear shackles of course.
notenuffcash
I have air shocks in my dart, I was using them to raise the cars rid height, but after reading posts I dont want to do that anymore. When you use the air shocks to raise the ride height, you are putting the weight of the car on the shock mounts. The bottom mount can probably take it, but the top mount is stamped sheet metal attached to the body. It may give out.
Jack Handy
urchinhead
An old "trick" that people use is to order "high lift" shocks from JC Whitney so that the tires don't rub, either front or rear, or both. But like notenuffcash said, you're compromising the quality of the ride, and safety, by putting the weight of the car on the shock mounts / body. That's why it is so important to install the correct length shocks, and why there are so many endless application guides for both stock and modified suspensions.
Ace
What are the dimensions of the leafs on our A-Bodies? I was curious on how many inches the arch was and how many lbs/inch would be ideal.
Thanks and sorry for the thread jack.
I have used add-on helper coil springs for my shocks before on my Dakota, I lowered the truck and the springs were too soft, the coils helped and actually worked OK.
moparrr07
right, you shouldn't use air shocks to raise the ride hight- while your at it, why don't you just take out the leaf springs  buy taller springs, drop front mount, longer shackle
50% custom interior
moparteacher
The correct ride height for a passenger car leaf spring is the leaf to be slightly concave, almost flat. You should be able to draw a straight line from the front eye through the bottom of the axle housing (top of the spring pin) through the rear shackle lower eyelet.
An arched spring is fine for straight line acceleration, but causes oversteer in a turn. This because the rear axle center line shifts outward as the outboard tire receeds in to the fenderwell.
A collapsed leaf spring causes just the opposite. Understeer in a turn.
A flat leaf spring car will have a more predictable steering response, and a safer one.
Moparteacher
notenuffcash
O.K. This is some good information. Now I have called a few spring companys, and have quotes of about 200 dollars delivered. Now what if I used longer shackles? In the rear of the spring? What effect will that have? I am pinched for money, trying to make every dollar stretch. I want to raise the ride height 2".
Jack Handy
urchinhead
Are you going for that ugly 1970s Starsky and Hutch look? Why would you want to raise a 2 wheel drive 2"? You'll shift the balance of your car forward, and get less traction and horrible handling. Why don't you just relocate the springs or mini-tub if you want bigger tires?
P.S. Shackles are only in the rear of the spring, it's a cheap fix for sagging springs to add an adjustable shackle, and you can make one for pennies, but if your springs are shot, just buy some new reproductions - you want flat springs and a level car.
notenuffcash
I dont look anything like starsky or hutch.... except the muschtache maybe. The car sits too low in the rear for my liking. The Bankers Toy has the ride height that I am looking for.
Jack Handy
urchinhead
If the rear sags lower than the front, then you need to replace the springs. But you don't want to jack up the back of your car, as it's hell for handling and it shifts all the rear weight to the front, so you lose traction ( it's great for a burn-out machine though ), plus it looks like sh*t. I remember all the Mustangs and Novas in high school that rode around on longer shackles, and they looked and performed like complete crap, except for smoking the tires out of the parking lot...
urchinhead
You know that theBankersToy's avatar is a just a cartoon?  You are joking...right? ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif)
notenuffcash
I didnt see his avatar. I did see pics of his sons car, a 72 dart I believe, yellow.
Jack Handy
oldkimmer
U could always get ur leafs re arched at a spring shop or add an extra leaf into ur set.........KIM.........
moparwedden
 Hooly Shit So Much Information Were Do I Start. Well Its Solely A Street Car. I Know The Front End Has To Come Down As I Had The Every Thing Out Of The Car On The Front And Its Going In In A Couple Of Weeks For A Front Inlighnment. My Question Now Is That I Was Told To Have The Top Of The Tire 3/4 Of An Inch From The Wheel Well Lip. Is This True. I Am Running 215/60 15 inch Tire On The Front. Its Sitting About 3 inches Wright Now. How Do You Lower The Front End Down. I Don't Now How But I Know I Can If I Had Some Pics As What to Do.
oldkimmer
There is a 1/2 bolt in the lower control arm......lefty loosey righty tighty...........kim.....
thebankerstoy
Both my son's 72 Dart and my 66 Coronet use Mopar Super Stock leaf springs and KYB gas shocks. Pictures below.
Richard
notenuffcash
I love that stance!!! Thats what Im looking for. Mine is a 72 also.
Jack Handy
thebankerstoy
 I really like the Super Stock springs and KYB shocks and with all of the front suspension work that was done on both cars, they also handle pretty well for the old school technology that they use. Richard [attachment deleted by admin]
jacks62440
You can always level your car a bit with adjustable front hangers
Jack
