Topic: Master Cylinder ??????? (Read 501 times)
71 Pro Street
Tell me if this is the same as the type that everyone sells. Its a 1987-1995 type and the oem part # for this is 4294865 which superseeds to 4509082. 71
I believe that one works best if you have a canted bulkhead i.e.the firewall is slanted. Not one I would get as the first choice in a Dart or other pre early 80's car.
 Get one for an 81 dodge truck . It is aluminum and should have a rectangular ( not wedge shaped resivor ) was designed for front disc and rear drum , but i have used it with rear discs as well. They are cheap from autozone as well.
chryco
Mine`s a 85 Dodge Ramcharger unit and is aluminum. Chryco  [attachment deleted by admin]
jackie
is their a aluminum master cy. that will fit on a e- body 70 challenger with drum brakes ,this is the one with a bolt in the cap.
are those two bolt MC's? the one in mine, while fully functional looks like a junkyard special the last owner rebuilt (a lot of surface rust, no paint etc). it just detracts from the clean look of the engine bay a lot.
go to the junkyard and swipe an earlier rwd resivior. they just pop out, pretty sure that is the only difference.
Jim13
San Antonio, Tx
What are you using for a spacer or adaptor to mount it to your firewall?
What kind of piston did you use?
jacks62440
Another thing I forgot you will need a rubber dust boot for the back of the MC . Rick Ehrenberg said that it's not needed but it's not a bad Idea . It's only $5 and you can get one from MagnumHP There is a Good Tech piece about Brakes and other stuff there. Good people to deal with too. http://www.magnumhp.com/mastertech.php
Jack
he was saying just get the plastic reservoir for it, then go down to your local napa or advance and buy the master cyl, its alot cheaper
