August 28, 2008, 01:57:25 PM
| | |-+  Spring relocation without cutting into the frame? A body
Author Topic: Spring relocation without cutting into the frame? A body  (Read 1447 times)
Junior
« on: March 09, 2007, 12:45:16 AM »
Has anyone used the existing spring mounts and welded them under the rear frame rails instead of cutting into them?
lake worth, florida
55robert@bellsouth.net
Re: Spring relocation without cutting into the frame? A body
« Reply #1 on: March 09, 2007, 02:11:06 AM »
i've heard of that but it raises the rear of the hotrod too much for my tastes.
Junior
« Reply #2 on: March 10, 2007, 04:11:10 PM »
I just had it done in my 68 Barracuda and it looks great. I had them weld the brackets in the bottom of the frame rail.  It was only 2" higher. ( I thought  Super stock springs are also available with a 2" lift?)   I installed Calvert Racing Mono leafs(Stock Replacement Size) I installed a 30" tall tire with a little cutting on the front part of the fenderwell. Very tight but it looks good. I also had them fabricate frame connectors. The 12 point custom cage is welded to the frame connectors through the floor. I also had the floor modified to accept race seats. Ill post pics next week.
There should be no bouncing of the rear with this set-up. Looks squared and strong. By the way, I kept factory frame rails and had custum mini tubs installed.
lake worth, florida
« Reply #3 on: March 10, 2007, 04:16:11 PM »
 Cool
Michael Deakin
« Reply #4 on: March 10, 2007, 05:33:52 PM »
Didn't midnight special make some front hangers for this.
Mike
Dart 440 GTS, 11.90 at 116, 1.75 60ft
ALLMOPARCARS
Cleveland,Ohio
« Reply #5 on: March 10, 2007, 06:12:25 PM »
Hello, If you look at my pictures on photobucket http://s133.photobucket.com/albums/q51/ALLMOPARCARS/
you will see a 75 duster drag car that i had, it had the boxes welded to the bottom of the frame. it sat a little high. but if you take a look at the 69 dart that we are currently  building. i have notched the frame rails and have added superstock springs and the rear tires that came off the duster the car sits about as high as the duster. i got the tech info right here on bbd sign and it was invaluable hope this helps if ya need any info feel free to contact me. Mike
OWNER/OPERATOR/FABRICATOR  (LEAGALLY),
ITS MY 13 YEAR OLDS FIRST CAR (69 DART GT) GOT TIRE?
SWEET! 4 speed
Junior
« Reply #6 on: March 10, 2007, 10:35:09 PM »
How tall is your tire and did you move it back a bit?
73swinger
Blackstock, Ontario
« Reply #7 on: March 10, 2007, 10:48:23 PM »
OK, just why wouldn't you cut into the frame if you've already added in floor connectors and a cage? most people that don't want to cut their frame to relocate springs just......don't want to cut their frame LOL. I used to be one of those guys, but I'm starting to think that traction might be important too. I think I'll plan it for next winter
ALLMOPARCARS
Cleveland,Ohio
« Reply #8 on: March 10, 2007, 11:27:25 PM »
are you asking about the front hangers or the rear shackle? on My duster the front hangers were welded to the bottom of frame and the rear had offset shackles, on the 69 dart we cut the frame and used the mopar relocation kit and welded the boxes into the cut part of the frame. and the rear shackles we drilled out the existing frame rail hole ( just like in the Tech pages) of bbd sign but mopar perf instructions said to weld the tube for the rear shackles to the bottom of the frame rail and make gussets and weld those onto the tubes. either way will work . and the tire size on our dart is 29x12.5x15 and yes we relocated the axle back about 1/2 inch or the distance from the front hole in the perch to the center hole in the leaf spring perch. Pefect fit with room to spare. hammer
SWEET! 4 speed
DartCustom496
« Reply #9 on: March 12, 2007, 05:44:51 AM »
Friend of mine has a 69 Cuda which the previous had weld the front sping hangers under the frame, what this does is that it raise the rear of the car and also throws off your positive caster on your front end , this winter we cut the frame and install the boxes.
Ft. Worth TX.
« Reply #10 on: March 12, 2007, 06:50:01 AM »
What would be the benifit of doing this?
Cary Snyder
5.7L Hemi Cuda
Junior
« Reply #11 on: April 02, 2007, 10:28:51 PM »
Tell me what you think.
I decided to use a rear bushing in the rear hanger also.  I can adjust stiffness a bit. I could also install solid aluminum bushings on one side or the other. This was done on my 68 cuda. I acctually had the rear moved back one inch. You cant see in the picture but my roll bar is just above the rear spring hanger.
sycboi
Huron, Ohio
bgpoppahall sycboi bgpoppahall
« Reply #12 on: April 02, 2007, 10:32:56 PM »
Looks fantastic man!
SuperBeast
'70 Dart
Roller 383 w/ much aluminum
Viper T-56, StreetTwin, hydraulic throwout, HD Dana 60, AlterKtion
An enforcer for the Mopar Mafia!
70 Dustpan
Sacramento CA.
« Reply #13 on: April 02, 2007, 10:34:13 PM »
Looks really nice. I can only wish I could weld like that.
Hey, I'm a God again!
Junior
« Reply #14 on: April 02, 2007, 10:42:27 PM »
More pics of the mini-tub. I used the factory frame rails
qkcuda
Caledonia, ON Canada
« Reply #15 on: April 03, 2007, 09:07:07 AM »
Excellent work.  But how are you going to be able to re-install the fold down rear seat?   hammer
Junior
« Reply #16 on: April 03, 2007, 12:48:13 PM »
I had planned on installing a Summit beach chair in the back.
rharveysr
« Reply #17 on: April 04, 2007, 09:48:28 AM »
Junior....
I have just one question....How long have you been welding?Huh?? Those are beautiful!
Rick
Crazy68Dart
« Reply #18 on: April 04, 2007, 12:27:26 PM »
I think Junior and Tom should hold a welding class for all of us Wanna-Bs.   Grin
rharveysr
« Reply #19 on: April 04, 2007, 03:15:13 PM »
You got that right....where do I sign up!  When I finish welding something people look for the flock of birds that flew over and let go! \/][ \/][ \/][...
Rick
Junior
« Reply #20 on: April 04, 2007, 09:00:01 PM »
I do not weld. A good friend of mine does my welding. He works for "Titan Offroad" in Orange county, CA. He does some real nice stuff. WWW.TITAN-OFFROAD.com    you should see the roll bars he does. NICE!!!
instrument
« Reply #21 on: May 01, 2007, 12:09:14 AM »
Damn that's nice...Now that's a buddy who's worth his weight in beer...........
69 340 dart swinger, 68 barracuda /6, 70 Swinger /6, 70 Charger 318, 69 Roadrunner 383,
Ft. Worth TX.
« Reply #22 on: July 15, 2007, 08:28:15 PM »
For some reason I missed these pics. This looks great. Those welds are just plain killer.
Cary Snyder
5.7L Hemi Cuda
