August 29, 2008, 03:33:39 PM
| | |-+  UCA Cam Bolt & Torsion Bar Questions
Author Topic: UCA Cam Bolt & Torsion Bar Questions  (Read 415 times)
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
« on: January 30, 2006, 12:39:29 AM »
#1 When installing the UCA's, does it matter which way the cam bolts are installed? (Been a while since I took em out LOL) Also is there a way to adjust them somewhat close to correct alignment wise so I'll be able to drive it to the alignment shop?
#2 When I install the torsion bars, is the correct procedure to let the front suspension droop all the way down to install them? What about the anchors on the LCA's? back the adjusters all the way off and let the anchors rest on the tips of the adjuster screws?
#3 I know this one has been asked before but which end is which and which is left/right?
thank you
Dr. Hunter S. Thompson
70 Dustpan
Sacramento CA.
Re: UCA Cam Bolt & Torsion Bar Questions
« Reply #1 on: January 30, 2006, 12:47:14 AM »
1. The cam bolt go from the inside with the nuts on the outside.
2. Yes drop the lower all the way down with the adjusters backed out all the way.
3. They will have a L or a r at the end of them.
Hey, I'm a God again!
70 Dustpan
Sacramento CA.
« Reply #2 on: January 30, 2006, 12:48:24 AM »
End to end don't matter as long as they are on the correct side.
Ryan (Strange246)
Merrimack NH
« Reply #3 on: January 30, 2006, 01:44:14 AM »
 thank you
jet-taz
« Reply #4 on: January 30, 2006, 05:22:03 AM »
i found if you let the lca drop to far and the torsion installed they won't go into the correct postion.the torsion bars do have a slight twist toward the front, i think the no. face the rear. as to aligment put on some crap tires till you get  there then swap them, that my 2cent worth duster
Ryan (Strange246)
Merrimack NH
« Reply #5 on: January 30, 2006, 11:35:07 AM »
Thanks man, I knew I kept the junk tires for a reason, now I can justify them being in the yard to Demongirl LOL
dmn71
Coal Valley, Illinois
« Reply #6 on: January 30, 2006, 11:56:31 AM »
I just talked to the guy Sat that is going to align mine.  He told me to measure the front of the tire from side to side and the same from the back of the tire, and get the measurement as close as possible to the same measurement.  He said I could drive it to the shop that way. Don't know how clear I explained this.  Steve
Ryan (Strange246)
Merrimack NH
« Reply #7 on: January 30, 2006, 12:46:35 PM »
Thanks Steve, simple enough...
Ryan
