Topic: Just suspension sway bars, any intel on 'em?? (Read 861 times)
440Dreamin
So they are selling front and rear sway bars for $99 ea, anyone have any experience on their products? Seems like a fair price.
Also do I want the 3/4" or 7/8" rear bar?
66dart gt, nothin sexy or crazy setup... just wanna keep the body roll in check
Thanks!
Fallen God member - just a schmuck now... Coon Rapids, MN
g-cuda67
I just got the front sway bar...niece piece though its an afco swaybar they are a steal for the money. Plus I got a box full of bolts the first time ..called justsuspension and they sent me a whole new kit no questions asked,really good guys.
67 barracuda notchback in progress 383 , 727 formula "craptackular" car pulled out of a ditch in Wa .
wickedfirefighter
oroville, ca
do they have a zert fitting for the rubber bushings so you can keep the sqeeking down ... i know thats was one of the reasons i got all my front and rear from firmfeel ..i got the 3/4 rear for my car .. it will be stiff ride but it will handle nice ..
but i paid almost $500 for front and rear bars ..
440Dreamin
mine will ride like a buckboard anyhow with 1.09 t-bars in it...
wickedfirefighter
oroville, ca
my car doesnt have t-bars anymore it has the adjustible alden coil over conversion on it with tube A arms .. they didnt help much for the ride...
FredDart
I have the addco front and rear swaybars from just suspension, cant beat 99$. I put some zerg fittings on the bushings, no big deal. I also welded ''L'' brackets on the k member to help support the sway bar bushings (near the strut rod holes). The stock bar is only holding by 2 brackets bolted to the k member with 3/8 bolts.
Fred
wickedfirefighter
oroville, ca
is ther rear bar mounted on the top or bottom of the rearend ?
FredDart
Bottom
wickedfirefighter
oroville, ca
that must be the differance bettween frimfeels and addcos.. firm feels mount on the top like the TA cars did .. i think addco bars a chromoly and firm feels are mild steel ...my 75 dart sport im probly gonna go with addco and save some bucks.
bbscamp
Just ordered my front bar for the 64 2 days ago.... $99 bucks plus shipping. 1 1/8 bar. I have 6 leaf HD springs out back, so I'll skip the rear bar for now. I'll see how it rides first. Im gonna take a lot of pix of the install, I'll post them on the early A forum.
bbscamp
heres the picture of the 64 1 1/8" bar. $99 bucks
BrianT
It's 1978 all over again!!
Looks like you had that table made for a sway bar!
$99 complete, that's a good deal. I was thinking about going with their street/strip kit when I rebuild my front end in a few months. Finally going to get rid of the 9" drum brakes on front!!
 67 Dart 340 "Doing everything ass backwards"
I installed a ADDCO front Sway Bar on our daily driver '68 / 383 with .920 torsion bars a few weeks ago..
The Sway Bar made a considerable difference in handling.
BrianT
Those are the same torsion bars that I am running. Noticed a big difference with those and new shocks alone. Then added welded in sub frame connectors. Again, big difference. Tightened up steering box, wow!!
I don't know how the previous owner kept this thing out of the ditch!!
bbscamp
Here is the problem with the early A brackets...they want to set on an angle, when they are best straight. I'm going to try and fab some brackets that will take the turn out of them. BTW....its much easier on the bench!
I think I'm going to order a set of those F & R along with a front susp rebuild kit and KYB shocks next month when I get my bonus.
Duster440
I want to confirm that these kits work on cars not originally equipped with bars - is that right? Couldn't get an answer from JS.
440Dreamin
by the looks of it - yes
Two Lane
Yes, they work on cars that originally had no bars from factory.
Have the Addco 1 1/8th" Front & the 7/8th" Rear on a '71 Duster, w/ Edelbrock gas shocks.
Totally different car --- much nicer ride, and far safer to drive.
Duster440
Great, thanks! And I presume it won't interfere with forward mounted brake calipers? How is the rear bar mounted?
I bought the shock plates that bolt to the leaf springs w/ u-bolts . I also bought their pinion snubber and I think I bought a tranny mount from Just Suspensions. Excellent quality and customer service. I have recieved 2 follow-up calls from them wanting to know if I'm satisfied with their product and if I have any suggestions as to improvements or new products "we" need they could start supplying. Top notch product and service!!!!!  [attachment deleted by admin]
mrbill00
Middle Georgia
can anyone send me a photo of the front bar bracket attach points. i think i'll have interference with the radiator support and the radiator hose if i put the bar up and use the bottom bracket mounting hole.. using the top hole the bar hangs waaaaay down.. this is on a 68 V8 valiant, thxs, mrb email: mrb_racingii@bellsouth.netps- rear bar went on as advertised
