July 20, 2008, 11:52:05 AM
| | |-+  whats the largest tire you fit under a Duster rear wheel well
Author Topic: whats the largest tire you fit under a Duster rear wheel well  (Read 658 times)
440darting
« on: March 12, 2007, 06:16:45 PM »
I have a 73 Duster with stock 8 3/4 a -body rear with sure grip with super stock springs, whats the largest  rear tire anyone has fit on a Duster that hasn't had the springs moved inward , would you know the rim size the tire was on with how much backspacing
BabyBlue383
Re: whats the largest tire you fit under a Duster rear wheel well
« Reply #1 on: March 12, 2007, 08:51:34 PM »
I would like to know too. We are looking into the torque thrust II. 16x9.5 in the rear and 16x7 in the front but our 8 3/4 axle is stock length " for a A body"  and the springs are the original /6 ones. What is the difference in the super stock ones?   bbd sign
farmington
Metro Detroit
« Reply #2 on: March 13, 2007, 12:41:46 AM »
I have 275-60-15 mt drag radials on 15x8.5 centerlines with 4 5/8 backspace, but I have the 1 inch offset spring package.  Have about 1/2" to spring.  One thing to remember with any car, production tolerances might let a wheel/tire fit one duster but not another.  A good tire store will have a fixture that will let you see how a particular package will fit in your car.  I highly advise it, or if buyint used wheels and tires try them on before shelling out the cash.
When in doubt, Whip it out!
Evan
Fayetteville, Arkansas
bigjohncat
« Reply #3 on: March 13, 2007, 08:09:29 AM »
Hey, yall should check out the link at the top of the page:
http://www.bigblockdart.com/index.php/topic,3550.0.html
I fit 295/50R15 on mine, but the back end was a little jacked up!
farmington, that is a good looking duster
dustyswinger
« Reply #4 on: March 18, 2007, 09:18:00 PM »
I have a 30X9 radial slick( that actually measures 29.5) on a 73 duster and the only modification I had to do is center the axle in the wheel well. The wheels are 15X8 wels autodrag I think with 4.375 or 4.5 backspace. Craig
dodgedemon1
« Reply #5 on: March 20, 2007, 09:59:09 PM »
Fit 28x12.5 under mine with little mods to outer fender well.Ray
70dusterjohn
« Reply #6 on: March 24, 2007, 08:37:54 PM »
I had a M/T 29.5 X 11.5-15 with the right off set rim and a baseball bat! Take the air out of the tire or lower it to about 3lbs and roll the car with the bat on the tire!!!!!! It did rub a little on the springs when going around turns.
STOMP AND STEER
440dstr
« Reply #7 on: March 24, 2007, 09:34:12 PM »
what about mini tubbed cars , come on guys lets see some pics of your hard work ,i know we can get more tire under our cars than these dart guys can !!!!
Cudadust
« Reply #8 on: March 26, 2007, 02:59:04 AM »
I have 235X60X15 on the rear of a 74 Duster with BFGs with 215X60X15s on the front, the car sits level at factory ride height measurements. The diameter of the tires are 24.5" front, 26.1" rear, the tires are fitted to 15X7" cop wheels.
BabyBlue383
« Reply #9 on: March 27, 2007, 08:54:33 AM »
I would like to mini tub our Duster but the wife want it to look factory as possible but I explain to her the benifits of a fatter tir means better grip "when your racing a stang".
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
« Reply #10 on: March 27, 2007, 10:11:39 PM »
For reference to show the wife, 72 Demon, mini-tubbed, springs moved in, wheel well lips in back trimmed...
Back-M/T ET Street Radials 325/50/15's on 15x10 Weld Pro-stars, 6.5" backspacing
Front-195/70/15's on 15x5 Weld Pro-stars
Ryan
Dr. Hunter S. Thompson
BabyBlue383
« Reply #11 on: March 28, 2007, 01:44:22 PM »
Thats a pretty fet tire, Is it gonna sit lower in the rear? I would like ours to sit down on the tires. But I'll show her. Heres one of our car as it looked before the transplant. She got it for 2,000 about 11 years ago from the original owner.
moparrr07
working on custom console
« Reply #12 on: March 28, 2007, 02:25:16 PM »
my dad ran in his 72 duster a 31x13 which translates into roughly a 330/60/15- he had stock frame rails and bent over the lip, but he did have tubs, he was telling me, you cant get any more width than that unless its only 26 inches tall, then maybe a 13.50 but i suspect you should be able to fit a 28x12.5 no problem with at least 3/4 inch on each side in a minitub (just like Ryan's setup)
brakes, 11 3/4
60-0: 105 ft.
cornering gs: estimate: .90
50% custom interior
Ryan (Strange246)
Merrimack NH
« Reply #13 on: March 28, 2007, 10:00:53 PM »
Yes it'll sit lower, since those pics were taken I dropped the rear suspension 2" and switched to HD leaf springs instead of Super Stocks which lowered it another 1-2" I'd snap some new pics but it's covered and up on wheel casters right now....Not to mention the car is just a shell in those pics with no motor, battery, fuel tank or interior at all....To make a long story short,  Blah Blah Blah the top of the tires is up in the wheelwell now
Ryan
