August 27, 2008, 07:42:16 PM
| | |-+  question about a steering box
Author Topic: question about a steering box  (Read 305 times)
west
« on: March 13, 2007, 07:39:59 PM »
in this ad it says it uses "small sector" piman arms.how many teeth are on a small sector arm?
Is this just the difference from pre 73 and 73 and up models?
http://www.reillymotorsports.com/store/product.php?productid=16140&cat=254&page=1
                moparts can kiss my ass  moon
71 Pro Street
CENTRAL JERSEY
Re: question about a steering box
« Reply #1 on: March 15, 2007, 10:43:40 PM »
I'm not sure of the teeth count off hand but the small sector takes a Moog Pitman Arm. 73 & Later takes Part# K7075, 67-72 takes Part # K7074. Cost is @$45-$55. The only difference I believe between the 2 arms is the position where the joint on the arm attaches. 67-72 attach from the bottom of the drag link and 73 and up attach from the top of the drag link.
ta3834bbl
« Reply #2 on: March 16, 2007, 07:06:23 PM »
I have read that the small sector is 1.11 inches in diameter and the large sector is 1.22 inches (at the spline)  my manual and power were both 1.11 and I was able to swap pitman arms between them when I put the manual in last weekend.  Power box was ball joint stud down, and manual box was ball joint stud up(threads)/
I am building a 68 cuda from a shell.  Might make a Formula S or hemi look-a-like.    383 powered, 727 or 4spd , and 4.30 geared 8-3/4. Front disk conversion done with volare parts and home modified upper control arms.  Rear disks next using parts of 96 Grand Cherokee 4x4.
jackie
« Reply #3 on: March 19, 2007, 02:37:56 PM »
did you use a old manual box or new one?
ta3834bbl
« Reply #4 on: March 19, 2007, 04:25:23 PM »
Old one.
375InStroke
« Reply #5 on: March 21, 2007, 07:44:55 AM »
