October 12, 2008, 08:01:54 PM
| | |-+  mounting fuel pressure gauge
Author Topic: mounting fuel pressure gauge  (Read 470 times)
340dart
« on: March 19, 2007, 07:16:25 PM »
hey i like the look of the outside chrome fuel pressure gauge but i dont want to wreck the car(drill holes)  has anyone ever done this???
thanks chris
lake worth, florida
55robert@bellsouth.net
Re: mounting fuel pressure gauge
« Reply #1 on: March 19, 2007, 07:22:39 PM »
velcro  Roll Eyes
west
« Reply #2 on: March 19, 2007, 09:10:20 PM »
never done i t,don't like the look pesonally.but i would think if you ran a strip of metal between the hood and cowell and if you had to drill holes it would only be a couple behind the weatherstrip seal on the cowell.
mrhotrod
Chicago,IL
mrhotrod1964@hotmail.com mrhotrod1964
« Reply #3 on: March 19, 2007, 10:16:36 PM »
Bolt and washer thru fins in cowl from bottom. Pull windsheild motor and you can get to it. No drilling or fabricating.
1972 Big Block Scamp 9.80 @ 138mph
2006 Cummins Turbo Diesel Ram 4x4 Dually
1966 Plymouth Valiant Big Block Project Car
340dart
« Reply #4 on: March 21, 2007, 06:52:02 PM »
if i would pull the windshield motor how would that help?Huh theres no way to get in there unless u pulled the drivers side vent tube??? Dunno
maybe im just retarted hammer
west
« Reply #5 on: March 21, 2007, 07:01:35 PM »
is this for asthetic reasons or is it to keep the mech. gauge out of the cockpit.I'm wondering if they make an electronic gauge that reads the mech. gauge,that way you can get an accurate reading from inside the car without an external gauge.
mr. hotrods idea would work fine,i have big hands and they barely fit inside the motor hole but they do,not sure what you mean by pulling the vent tube.
Long Island, NY
« Reply #6 on: March 21, 2007, 08:29:37 PM »
Does Autometer still make that guage isolator? It allows you to have a fuel pressure guage in the cockpit.
tubtar
« Reply #7 on: March 21, 2007, 08:53:13 PM »
I used some strips of an old inner tube and a small hose clamp to tie mine to the slots on the cowl.
The hood just clears it when opening and it looks alright to me.......now........has anyone ever put a large tach on their dash in a '65 dart ?
I have a 5" Autometer and it isn't gonna go anywhere I can see it whilst driving unless I take my eyes off the road ( a bad thing )
There are isolators ( Autometer makes one ) , but the gauge sitting on the cowl makes a statement even when parked.
        J.S.
It's a fine line between " how much ? " and " Why the hell not ? "
moparrr07
working on custom console
« Reply #8 on: March 21, 2007, 09:11:29 PM »
i found one of those isolators in a box out in our show, its red and says autometer on it, thought it was a fuel pres regulator when i first looked at it
http://store.summitracing.com/egnsearch.asp?N=700+4294845469+115
heres a search on summit- other places you can still buy the big red one, looks like mallory one
brakes, 11 3/4
60-0: 105 ft.
cornering gs: estimate: .90
50% custom interior
Long Island, NY
« Reply #9 on: March 21, 2007, 09:48:11 PM »
In my opinion, I think it looks kinda twenty years ago.
W2-408
Leduc Alberta Canada
« Reply #10 on: March 21, 2007, 11:51:01 PM »
I used a small piece of aluminium flat bar that would fit throught the washer sprayer hole, drilled and tapped 2 holes in the alum, and slid it in enough to get the first screw through the gauge bracket and into the aluminum, then slid through some more to install the second, then moved all back towards windshield. For the line, I just 3/16" brake line tubing and ran it out through the same hole, if you want I can snap a pic or 2. It was actually quite easy.
1973 Duster 360/904,  11.34 @ 119.15mph...... for now, and still driven almost daily
sunsetdart
us4ever365@hotmail.com
« Reply #11 on: March 22, 2007, 06:24:32 AM »
 Putting one outside must require a good mount, you do not want the gauge to shake itself loose and have gas sprayed all over the car.......big fire!!! If you put one in the car with an isolator, the gauge MUST be higher than the connection at the fuel line. The line is filled with an antifreeze, so when you work with the line , be careful as not to allow the coolant to flow out. It has a coolant in the line for the pressure to be read correctly, that way you dont have raw gas coming into the car attached to the guage.
GON_RACIN
Happiness is a warm gun.
« Reply #12 on: March 22, 2007, 07:40:14 PM »
A friend of mine had has fuel pressure guage mounted on the outside of his Demon, on the cowl area.  He left the car parked somewhere one night and some jackass decided to try and steal the gauge.  The thief destoyed the cowl trying to remove a 50 dollar gauge.  I used a isolater and mounted mine in the dash  Grin
mrhotrod
Chicago,IL
« Reply #13 on: March 28, 2007, 12:30:46 PM »
chryco
« Reply #14 on: April 01, 2007, 11:10:36 AM »
Try this . It`s working for me , watch your hood clearance if you have a hinged one.
    Chryco Wink
Hemi Darts Rule !!!!!
west
« Reply #15 on: April 01, 2007, 12:17:30 PM »
    Chryco Wink
thats exactly what i was talking about,i think that is safest and least dammaging way to mount it.
