October 12, 2008, 10:36:00 PM
| | |-+  suspension parts
Author Topic: suspension parts  (Read 592 times)
jackie
suspension parts
« on: March 21, 2007, 03:56:06 PM »
what are you using for control arm bushings, ball joints ,swaybar bushings, ect...... polygraphite, rubber, polyurethane, ?? and where are you buying them?
A13Dart
Minnesota
Re: suspension parts
« Reply #1 on: March 21, 2007, 04:20:13 PM »
I use poly upper control arm bushings and rubber (stock type) lower bushings. For ball joints, tie rod ends, etc,  I like Moog parts from Mancini racing.
moparrr07
working on custom console
« Reply #2 on: March 21, 2007, 05:14:26 PM »
i used just suspention poly bushings on everything including lower control arm- alot of people use a rubber one- and i am very happy with them, greased them up really nice and have only heard them squeak twice but that was down around 0* one cold morning
brakes, 11 3/4
60-0: 105 ft.
cornering gs: estimate: .90
50% custom interior
jet-taz
« Reply #3 on: March 21, 2007, 05:35:38 PM »
go with moog parts. using poly bushings. check on what type of lower control arm bushings in poly. some ,you need to leave the sleeve on the lower control shafts. some don't. Wink
Dcuda69
WI
« Reply #4 on: March 21, 2007, 09:53:26 PM »
I also used Just Suspension poly graphite on everything. Great people to work with and fitment was fine. So far(about 8 yrs) so good. However I do know Moog makes some quality components(have used them in many other apps.) Anyone seen the newer NAPA stuff? Sales guy just showed me some cutaways of ball joints and they look good! Dunno
kawazuki8097
New Cumberland PA
ray@keukaco.com kawazuki8097 kawazuki8097
« Reply #5 on: March 22, 2007, 06:25:29 AM »
I am running poly stuff in the '73. I got it along with the front end tool kit (a must have!) from ESPO.com. Even though things were greased up well, I still notice some squeaking. The front of the '67 is next. From what I have read, it seems best to go rubber on the LCA and poly everywhere else.
Only two people ever died for you,Jesus Christ and the American GI.
One died for your soul the other for your freedom.
jackie
« Reply #6 on: March 22, 2007, 08:00:38 AM »
thanks guys, time to order & go to work...
Michael Deakin
« Reply #7 on: March 25, 2007, 04:49:17 PM »
Why do people use the rubber bushings for the lower control arms also the mancini kit comes without the outer shell, do they not wear.
Sorry to hijack.
Mike
Dart 440 GTS, 11.09 121.31 mph 1.66 60ft
Cudadust
« Reply #8 on: March 26, 2007, 03:03:13 AM »
Sorry to hijack.
Mike
The Urethane bushing will not seat properly, and when tyhe white grease is applied the bushing can be inserted and removed by hand.  The proper torque cannot be applied even with an air tool because the bushing will spin even with the full weight of the car on the suspension.
jackie
« Reply #9 on: March 26, 2007, 10:09:47 AM »
how do you remove the lower control arm bushing &  pin? .. do you just press out the pin and then press out the bushing? looks like you press the pin out through the torsion bar hole..
kawazuki8097
New Cumberland PA
« Reply #10 on: March 26, 2007, 11:26:44 AM »
Check out the American Muscle front end tools for the Mopars - most all of the big suspension places carry them.
They make things incredibly easy when rebuilding out cars. The kit I got has the tools for pulling the pins, replacing LCA and UCA bushings, spliting ball joints and for removing the T bars. They save alot of blood sweat and tears when rebuilding the front end.
Bill had a big write-up on the rubber vs poly LCA bushings here somewhere - poke around the tech pages.
jackie
« Reply #11 on: March 26, 2007, 03:54:33 PM »
well i took apart my front suspension, cleaned everything up, decided to sent the upper control arm to the front end shop , so i would not mess it up,, guess what: the man called me back .he had bent one of them BAD, &stripped out both of them where the balljoint screws in.. i dont think i could have screwed them up that bad.... now where do i find 2 upper CA for a 1970 challenger...
west
« Reply #12 on: March 26, 2007, 04:00:20 PM »
stripping them is one thing,and i would write it off.but bending them is not cool and pretty lame.
Colt1911
« Reply #13 on: March 26, 2007, 04:05:21 PM »
I would throw it back in his lap and have him find you new control arms. He screwed them up not you.
Cudadust
« Reply #14 on: March 28, 2007, 12:06:03 AM »
The shop is responsible for replacing the damaged parts and repairing them at the original price quoted, its called cost of doing business.  Why not upgrade to the newert type UCA, bill should be able to help with the conversion.
jacks62440
« Reply #15 on: March 28, 2007, 12:41:54 AM »
I would say the shop has Some Responsiblty alright . I would go after them , but you may not have much Luck      As far as your front end parts go , I went with the Complete "Poly Graphite Kit" from PST  Good price and Good parts .
Jack
x360x64dart
« Reply #16 on: March 29, 2007, 10:10:39 PM »
   This article helped me with rebuilding my lowers   http://www.moparmusclemagazine.com/tipstricks/155_0306_control_arms/ and i got the "g machine" kit from perfomance suspension     http://performancesuspension.com/    all poly minus the lowers, i was urged to use rubber on them.
It's almost a big block! Escondido,CA
jackie
« Reply #17 on: March 30, 2007, 08:41:44 AM »
hey, thanks a lot . the tips on the lowers are great, just what i needed because i am doing these myself.  going today to "just suspenion"  to pick up new uppers , will get paid back by front end shop,so i am told..GREAT!!
Birdius Rapidus
« Reply #18 on: March 30, 2007, 09:17:57 AM »
Press out the pin. Remove the rubber by flame or other means. Weld a washer inside the shell and press it out.
jackie
« Reply #19 on: April 02, 2007, 12:04:48 PM »
pressed out the pin, pulled out the rubber with a screwdriver, welded a washer , pressed it out, pressed the new one back in ,piece of cake , i wish everything was this easy.. thank for all the info...i went to "just suspenion" friday and they were out of upper c. a. ,should be in about 2 weeks .
kawazuki8097
New Cumberland PA
« Reply #20 on: April 02, 2007, 03:03:37 PM »
What are they asking for theirs? Are they used or repop?
jackie
« Reply #21 on: April 03, 2007, 07:52:05 AM »
new.. polished stainless steel with ball joints& bushings $299.00 a set.. or black tubelar $399.00  .the stainless ones are very nice!!
