October 06, 2008, 10:24:24 PM
| | |-+  back up lights
Author Topic: back up lights  (Read 132 times)
moparwedden
back up lights
« on: March 21, 2007, 07:05:48 PM »
 72 duster. Is The Wiring Plug For The Back up lights On The Wiring Harness For The Lights. And If So Does It Have Power At All Times.
cu440da
Saint Paul, MN
Re: back up lights
« Reply #1 on: March 21, 2007, 10:10:05 PM »
There should be wiring on the rear lighting harness for them. No, they should not have power at all times, only when in reverse.
'67 Notchback- 12.85 @ 109mph
cu440da
Saint Paul, MN
Re: back up lights
« Reply #2 on: March 21, 2007, 10:13:08 PM »
I just caught your other post. I thought you were asking about the back up lights. The other post sounded like you were talking about about the reverse indicator light on the dash.
moparwedden
Re: back up lights
« Reply #3 on: March 22, 2007, 03:36:18 PM »
Actually I'm Talking About The Harness In The Engine Bay For The Lights. I Hooked Up The Only Two Wire Plug Off The Light Harness And Ran Two Wires Too The 4 Speed. My Question Is Does This Feed Not Need Power At All Times So The Mecanical Swith In The 4 Speed Too Work. Because I Have No Power To The Plug That I Think I Am Too Use.
Re: back up lights
« Reply #4 on: March 22, 2007, 05:33:58 PM »
There should be power to one side and none to the other.
moparwedden
Re: back up lights
« Reply #5 on: March 22, 2007, 08:27:00 PM »
 motorinstall Well No Time To Try And Fix The Lights So I Bypassed The Original And Run A New Feed Two the Rear Harness And Ran A Hot Wire Two The Light Switch, Works Fine. Thanks Guys now Its Off To The Shop To Get It Saftied And Front Inlighnment . Then Off To Paint. Boy Its Been A Long Two Years, I'll Post Some Pics After Its Done. Again I Could Not Have Done It With Out This Group Called bbd sign
