Topic: PROJECT S6 to V8 -what's REALLY needed? (Read 1409 times)
bbscamp
OK. a shopping list of what is needed to do my planned 64 S6 to V8 (SB) conversion with the school kids. The plan would be to build a quick, VERY good handling car. 1) V8 drop centerlink (1" more drop than S6) (Ffound one, it should arrive next week) 2) L.side exhaust solution (I'm going with early 273 CI manifolds (got them) 3) V8 mounts (easy enough....Schumacher) (just gotta make a call) 4) LBP Disks: 73 Disk setup with UCAs (gottem") 5) 8 1/4 suire-grip with 3.55s (got it) Questions raised; comments or solutions? 1) V8 gas pedal assy....are they really diff. than S6??? 2) Radiatior? Upper tank hose usually not an issue, lower? SB lower tank outlets moved from L (drivers) to R in the late 60's. Outlet sizes change too S6? SB? BB? 3) Later (donor 1967) 904 speedo drive not compatible with 64 speedo? true? what's the fix. 4) Custom driveshaft needed. 5) shfiter for 904? (floor / console?) 6) Front sway bar options? 7) rear sway bar options on a stock A body 8 1/4?  frame connections or any suggestion on stiffening the structure so it will handle? 9) A L T E R K A T I O N ? ? ? ? ?
abodyjoe
i figure if you go with # 9 then you may as well stick a big block in it...
LILBLUE65
1) V8 gas pedal assy....are they really diff. than S6??? ---yes 2) Radiatior? Upper tank hose usually not an issue, lower? SB lower tank outlets moved from L (drivers) to R in the late 60's. Outlet sizes change too S6? SB? BB?-- Get a 273 Rad or go aluminum. 3) Later (donor 1967) 904 speedo drive not compatible with 64 speedo? true? what's the fix.-- I'm in that pickle myself (BB though) 4) Custom driveshaft needed.-- I mesured to fit with 727/ 8 3/4 5) shfiter for 904? (floor / console?) --Go floor with cable (my opinion) 6) Front sway bar options?-- unless you are going out on a roundy round, no need. 7) rear sway bar options on a stock A body 8 1/4?-- see above frame connections or any suggestion on stiffening the structure so it will handle? see the tech section of the old board. 9) A L T E R K A T I O N ? ? ? ? ? If you can afford it, Bill's wife needs a new house.  I was very lucky cause my parts car was a 63 A body BB conversion. i had most done for my 65. What I have learned is that every car is different. Rob
gentrysgarage
Here's my take on this (notice I will near mimic Rob's Replies) 1)? V8 gas pedal assy....are they really diff. than S6??? YES this should be next on your hit list!2)? Radiatior?? Upper tank hose usually not an issue, lower?? SB lower tank outlets moved from L (drivers) to R in the late 60's.? Outlet sizes change too S6? SB? BB? Not too hard to find..most 22" early Chrysler rads are the same except the mounts (which are brazed on)3)? Later (donor 1967) 904 speedo drive not compatible with 64 speedo?? true?? what's the fix. Haven't done this yet..no answer sorry4) Custom driveshaft needed. Best easiest answer5) shfiter for 904?? (floor / console?) 1966 and later consule shift..or an aftermarket shifter..whichever you like best!6) Front sway bar options? After market, do a google search for "Lame Horse Racing" then search within results for Formula S.. he has it mapped out! 7) rear sway bar options on a stock A body 8 1/4? See above frame connections or any suggestion on stiffening the structure so it will handle? I do like frame connectors see the tech pages they are easy to fab9) A L T E R K A T I O N? ? ? ? ? ? When Bill can give me one, it would make my FirePower shoehorn job sooooo much easier! I will install it before the UPS driver starts his truck! If you can afford it, Go For IT!  You have done a good job getting the other parts together, but finding stock early V8 mounts might save you some dough...so you can aford number 9!!
blackshire
JC Whitney has front and rear sway bars by Hellwig for a very attractive price. Free shipping as well.
Hey bbscamp, make sure you check out the 65 Barracuda thread in this forum. There may be some available parts not that far from you.
cavemanmoron
I live near Albany NY USA
ski
Nice looking 64 engine bay. My 65 has a 22". I think either one would work fine.
fstfish66
speedo cable problem,,,,66 and down,,screw on at the speed o,,,67 and up push on type,,your 64 cable will work with 64 and up transmissions,,,,no problem,,,yes i agree alterkation,,,is the way,,,,,,,,,,,,,,,,
1966 barracuda blown 340 4 speed tubbed 33x22 1940 dodge street rod hemi with A/C 2002 cummins ram dailey driver
GT_convert.
Nice to see you building a 'handling' car. Get some springs and 'T' bars from a later (heavier) V8 car. I had '68 383 springs and a rear bar (Quickor) plus a added bar in the front on a '65 GT...it really handled well. All bolt in/on.
Road Racer 40 years of go-karts, motorcycles, & cars...with a hydro-plane every once and awhile to cool things down! No such thing as too much HorsePower!!
440Dreamin
I am doing similar with my 66 GT - i have a 67 273 going in - will the motor mounts from the 67 v8 fit my 66 k frame??
good luck to you bbscamp, if you find an extra gas pedal cable setup please let me know!
joel
Fallen God member - just a schmuck now... Coon Rapids, MN
