August 30, 2008, 12:30:22 PM
| | |-+  will it fit
Author Topic: will it fit  (Read 306 times)
wickedfirefighter
oroville, ca
will it fit
« on: March 21, 2007, 11:40:51 PM »
will the rear end out of a b-body fit under a 75 dart or is it too long ? Dunno
I have fourteen mopars and not even one is running ..
kawazuki8097
New Cumberland PA
ray@keukaco.com kawazuki8097 kawazuki8097
Re: will it fit
« Reply #1 on: March 22, 2007, 06:32:54 AM »
Early B - it will be a little wider, but will work with correct offset wheels. Can even leave the perches in the stock B location.
Late B - it will be alot wider and will need new perches welded on.
Only two people ever died for you,Jesus Christ and the American GI.
One died for your soul the other for your freedom.
5258
bigblockdart.com
Re: will it fit
« Reply #2 on: March 22, 2007, 09:03:20 AM »
We use a B Dana on our 71 Duster drag car.  To run 10.5" slicks we went with the Weld wheels and a 7.5" offset.  To fit these tires in we also did a spring relocation and did have to move the perches as well.
drag tree
5258 Performance  Shelbyville, Tennessee "Where the MOPAR factory built and race ready hotrods live again"
DustMan
Re: will it fit
« Reply #3 on: March 22, 2007, 02:39:26 PM »
As long as it is a Dart Sport and not a Swinger you can make it work with perches welded in 1/2" on each side.
The enemy of performance is weight
QK TIME
Re: will it fit
« Reply #4 on: March 22, 2007, 03:38:25 PM »
I used a late 60s b body rear in My Demon. I grabbed the leafs a pulled them out and the rear dropped right in. Not ideal but worked fine.
