Topic: Can't get these *#^% drums off!!!! (Read 615 times)
ValiantOne
Hey All,
Trying to get the drums off my 00 Ram 1500. Stuck on there like a mutha! Smacked at 'em with a dead blow. No luck. De-adjusted the adjusters. No luck. There is a little peep hole on the rear of the backing plate and I can see that the shoes are definitely backed off the drum. It is like the drum is rusted to the axle face. I soaked the studs and the axle end down with penetrating oil but who knows if it is even getting in there.
Any of you guys have some magic tricks for getting these things unstuck???
Thanks for any ideas,
Chris E.
W2-408
Leduc Alberta Canada
I've hardly ever had them require more than a couple of good whacks with a big hammer right between the studs. Use the flat end of the hammer. I'd say about 1 in 20 rear brake jobs I do require heating the drum up around the center with a torch, then a little tap and it'll pop free.
1973 Duster 360/904, 11.34 @ 119.15mph...... for now, and still driven almost daily
Joe-Dokes
Couple of thoughts: 1) have you removed the factory retainer clip that slips over one or two of the wheel studs to hold the drum in place during assembly at the factory? 2) spray the hub with a little liquid wrench and then hit the drum with a ball pean hammer, wait ten minutes and then try to remove. 3) try this: http://www.dieseltruckresource.com/dev/showthread.php?threadid=45008Hope this helps regards Joe
moparrr07
get some pb blaster and a torch
50% custom interior
GTS225
Anybody suppose that the drum is staked onto the studs?
Roger
oldkimmer
The Rams usually require some heat from a torch to free the drums from the axels........kim.........
71 demon child
Deadblow aint gonna cut it.Get something much larger like a 12 lb sledge and smack it on the corner...It'll let go.
carl
taking donations
ski
I think Joe-Dokes has it.
oldkimmer
And they say u cant teach an old dog new tricks....but they do say u learn something every day ......Thanks for the link Joe-Dokes.............Kim...........
ValiantOne
Thanks guys,
Yeah the clips around the studs have been removed. Back when I first got the truck I was really fastidious about cleaning/adjusting/lubing backing plate, etc. So the drums have been off. Now I have 170,000 mi and I have never replaced anything back there. Just want to have a look.
I'm going to give the joe-dokes tip a try. If that doesn't do it I guess I'll have to resort to some heat and a sledge. Yuck, I hate breaking out the torch for stuff like this.
I'll report back! Thanks again.
Chris E.
kawazuki8097
This trick worked very well on my F-150 and also on the Dak. No need to break out the big guns on this, a MAPP or Prop torch works just fine.
Only two people ever died for you,Jesus Christ and the American GI. One died for your soul the other for your freedom.
moparteacher
The drums are probably grooved and the shoes won't retract far enough. Use a good pair of dykes and cut the head of the the hold-down pins off from the back side.
Moparteacher
65DartGT
I've always had good luck using a ball pean hammer, using the round end hit between each of the studs , then using the flat side hit he axle instead of the drum. It usually jars the drum off the axle. if that doesn't work get out the PB blaster and torch. Just my 2 cents.
318_Magnum
Who ever thought something so simple could be so difficult? Kinda like changing spark plugs on a V6 import, or installing cheap traction bars on a 1st Gen GM F-body, "Oh yeah, no big deal, I'll be done in ten minutes..." ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif)
xxxxx  xxxxx 72 Demon 340/727/8-3/4 69 Barracuda Fastback 400/727/D60 76 Dart Sport 360/904/8-3/4 04 MazdaSpeed MX-5 Turbo, 6-Speed, Boost Controller, Intake, TB Inlet, Comp. I/O Pipes, DP, BOV, o2 Mod, FMIC & More
I once had to bang the drums off my old Escort with a large sledge hammer, me and my buddy had to take turns beating on it with all our strength for about 20 minutes, we used heat, cold, penetrating oil, it finally took the 12lb sledge about 50 blows, the brakes had never been off in 150000 miles. I was sure the suspension or hubs were going to break before the drums came off, but they finally did. That was the last Ford I ever owned.
moparrr07
50% custom interior
ValiantOne
Well, here is the update: The Joe-Dokes trick didn't work!  I think it has something to do with rear anti lock brakes. When I put her in drive, reved it up and stabbed the brakes it made a sound like when you lock up the brakes on wet pavement. The the drums stopped turning in stages. It was really weird. I even tried standing on the pedal with both feet.  So finally I broke out the map gas and a sledge. I did manage to get the right rear off with heat and sledge persuasion. The drums and the shoes look GREAT  !!! With 170K miles no less. Do the rear brakes even do anything on the Ram??? I am on my 4th set of front pads and the second set of rotors. Anyhow the right rear still won't come off. There is no shoe drum interference. it is definitely the drum rusted to the axle. So, for now I just adjusted them up and I'll hope that the left rear is an indicator of what the right rear looks like. Thanks again everyone, Chris E.
Stroked GT
im right next to the Pacific, to be specific
last time we couldnt take off the drum it was the stupidest thing that we all overlooked.... The E Brake was still on!! im sure you have made sure its not on but if you havent, well it could be the ebrake
 trying to reinvent the Dart, one dog dish at a time - Car Domain PagePlanned Upgrades: EFI - HID - AlterK - TKO - GPS - DUBs
magart
are the drums moving at all?...if they're not, they may be stuck behind rust build-up on the axle spigot...does'nt take much...use a good Snap-On seal pickand scrape it clean...does'nt take much...I've ruined drums and over looked that
Joe-Dokes
RE: Drums turning in stages.
What you see happening is the anti-lok brakes are engaging. Simplest thing to do is to go to the fuse block and pull the anti-lock brake fuse. This will disable the anti-lock brakes and should allow the brakes to stop with a much greater sudden force.
Hope this helps
Regards
Joe
ValiantOne
Hope this helps
Regards
Joe
![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif) I am such a dope! I will definitely try that the next time the wheels are off. Thanks again Joe
