Topic: V-8 centerlink (Read 483 times)
66dartman
When installing a V-8 centerlink to replace a/6 one, do you have to change the pitman arm as well? I installed a V-8 centerlink in my 66 and now the drivers side inner tie rod rubs the torsion bar. Is this common? Would like to find a fix before I put the /6 centerlink back in.
That thang got a 360 in it?
uwee440
I might be wrong but i think all the centerlinks are the same.Anyone elese?
Ray Barton Racing Engines
BOTTLE-FED_CUDA
I swapped out my /6 to v8 centerlink in my 65 dart and didn't have to change anything else, I'm pretty shure the only difference is the bend between the /6 and v8 bars. -ritchie
66dartman
the V-8 centerlink had more drop bend to it, but it seemed like it might have been a little longer. I bought it on ebay, it was supposed to be the link for 66-72 V-8 cars. Might be the wrong one?
Online
66 was the first year all a-bodies got the "V8" center link, BUT the width changed in 67, so you probably have the wrong part for your 66.
66dartman
Okay, I guess will pull it back out and keep searching for a 66 center link(good luck). If I am putting a 360 in the car with a stock center sump pan, do I really need it?
Online
You should have the proper link if your car is a 66 with the original parts.
66dartman
Thanks Jim, I am getting a new idler arm for it and I will just put the original /6 center back in it and if I need to I will clearance the oil pan.
bbscamp
From what I gathered from the Slant 6 siite is: 64 has nearly straight across S6 centerlinks and a 1" drop centerlink for the 273 v8s. some 65's used up the rest of the straight links...but by mid year....all (V8 and S6) got the same 1" drop bar. Your 66 should have the correct bar in it, unless it was changed out before.
