November 23, 2008, 05:39:29 AM
| | |-+  vibration problems 64 dart
Author Topic: vibration problems 64 dart  (Read 304 times)
64dartsb
« on: March 31, 2007, 04:32:03 PM »
I have a 64 dodge dart and I just put a 360/904   8 3/4    combo  When I get on the freeway the car starts vibrating really bad at 3000 rpm all the way to 3700 rpm and then it just goes away and I can cruise along fine but then if I dip down to like 3000 again it will start vibrating then I have to take it back up to about 4000 rpm again for the vibration to go away.  I tried throwing it in neutral while it was vibrating and it didn't help it at all.  When I first put the thing together the tranny was fine but I think it vibrated so much that it messed up the front pump seal on the tranny and now it leaks tranny fluid real bad.
the driveshaft hasn't been balanced  ,   the yoke sticks out of the tranny about 2 in.     ,      the pinion angle on the rearend is like 5 degree's up I think if I remember correctly  ,   It has a good tranny mount and there is no contact from tranny to crossmember or underbody
what do you guys think would fix it?  has anyone ever experienced this before?
bbd sign
If your dreaming of your car then it's your dream car
64 dart stock appearing, grocery getter, 360 2.02 in, 1.60 ex victor jr, aeromotive fuel system. msd dist, coil, wires, 6a, 125 shot of nitrous hedman 1 7/8 fenderwells 3 in exhaust  / 904 quarter stick, reverse manual,  /  8 3/4 3.91, suregrip
CARNUT
Re: vibration problems 64 dart
« Reply #1 on: March 31, 2007, 09:57:32 PM »
are you running the wright torque converter and crank balancer for a 360 they are diferent fron a 318/340
St.Louis-Dart
72 Dart 383-3:91-727 BBD baby!
« Reply #2 on: March 31, 2007, 10:11:41 PM »
My driveshaft is to short ..yokes out 2in but no vibration...no problems after 1 year...mild cam 383   3:91 power lock..8 3/4...  stock 727 (shift kit)
lake worth, florida
55robert@comcast.net
« Reply #3 on: March 31, 2007, 10:43:45 PM »
agree
64dartsb
« Reply #4 on: April 01, 2007, 06:15:16 AM »
yes I am positive that I am running the right torque converter it has weights on it for the 360 and the balancer is correct too.
signet
« Reply #5 on: April 01, 2007, 02:48:04 PM »
if it was the engine out of ballance it would happen at a stand still at the rpm you mention.
it sounds like the driveshaft is bent or the wheels and rubber are out of ballance.
kawazuki8097
New Cumberland PA
ray@keukaco.com kawazuki8097 kawazuki8097
« Reply #6 on: April 02, 2007, 02:05:35 PM »
With the DS hanging out so far, that could wreck the bushing on the tailshaft.
Running the DS out of balance will wreck the pinion bushing.
Only two people ever died for you,Jesus Christ and the American GI.
One died for your soul the other for your freedom.
64dartsb
« Reply #7 on: April 03, 2007, 03:01:47 AM »
so do you think that the driveshaft being out of balance messed up the pinion bushing and lead to the front seal failure too.
I think your right about the tailshaft bushing too it drips a little from there also.....
also does anyone know some website about how to rebuild 904 trannies and I've seen books on how to rebuild 727 will that work for the 904 also or is it completely different?
CARNUT
« Reply #8 on: April 03, 2007, 06:53:41 AM »
same thing but everythings smaller
instrument
« Reply #9 on: April 04, 2007, 02:36:35 AM »
Man, I'm going through the same trouble. The Drive line is in the shop, so I will see in a couple of days.
instrument
« Reply #10 on: April 11, 2007, 02:33:12 AM »
The drive line was bent and uot of ballance...Now I have no problems other then the desire to keep my foot on the throttle...Hopefully your trouble will be as cheap!
440Ken
You got a 440 in that? Spring Hill, FL
« Reply #11 on: April 11, 2007, 05:00:00 AM »
You say highway and 3000-3700 RPM. Does it vibrate at those RPM when setting still? If yes....engine if NO if may be wheel balance problems.....maybe.
Former "God Member" with 1180 posts
74' DART
Work in Progress
demonbbmopar@yahoo.com
« Reply #12 on: April 11, 2007, 08:50:01 AM »
I had the same problem a few years back, would only vibrate  at certain rpm's had a new driveshaft made balanced, still had the same problem. Usually a tire or wheel vibr. u can feel through the steering wheel , or the seat of your pants if its a rear tire. My vibration would shake the hole car, rattle the dash etc. When i changed from sb to bb it took my convertor to trans shop to have it looked at , there was a guy who knew mopars working there and he knew right away what my prob was. It was a 360 conv. not a 318. I ran my bb with the same drive shaft ,rear, tires, and never had another prob. Double check that convertor, it is poss. for them to damage front seals.   J.R.
