Pages: [1] 2 3 ... 6
Topic: check out my new RMS rear suspension ..(pics) (Read 20114 times)
71 demon child
Awesome!More pics please.Can't get enough.
carl
taking donations
back to my little 15X6 rally wheels..  extra parts..
i know bill has some other pictures that are probably better then mine. maybe he can post some of them..
very, very cool, the kit looks to be very simple but still extremely functionable, looks like practically infinite adjustability- any idea on when this kit will become available and about what the price on it will be? i hope its not too much
mopardude318
That looks real nice!!! I want one!!!
1970 Dodge Dart, 408 sb, eddy heads, 4 spd, alterktion, 8 3/4
Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax. - David Charles Gedraitis
Very cool system. I knew Bill was working on an air ride system, I didn't know he had a coil over system available.
This has been a project of mine for an extremely long time. I was bent on making a fully adjustable street kit with coils that still allowed the stock gas tank. Of course, this kit is only for the 67-up a-abodies. I use other stuff for the B/E's. It worked out really nice though. It took us about 8 hours start to finish, but I admit it would be better to call it a weekend project. I used in my carr last summer with good results, but Joes was the first one made on the jigs as a production piece, so I was worried about e-brake cables, brake lines, gas lines, ect - but it all went back into place pretty nice, everything fit the way I measured it to, so I can now say all the fab work is correct and accurate. The brake line on the rear has to be rebent because the parts are very close to the old clips on the axle, but that's a minor item, so I'm happy with it all. TTI tailpipes do not fit, but there isn't much you can do about that - I felt it was better to keep the stock tank and allow custom tailpipes to be made. I'm not a fan of fuel cells on the street. There will be 2 options - coil-over or air ride, and adjustable links like the pictures, or bushing-type links for more of a set-it-and-forget-it use. Price will be 1795 with either link, and 1895 to get the air ride shock upgrade. After a year of research, it's exciting to finally see it a reality. I wanted to keep it simple, so it took a while to find pivot points that offered a little anti-squat without any roll steer, and still had a roll center high enough that a sway wouldn't be needed. Welding of course is required, but no critical measuring, and a cheapy angle finder from sears is needed to play with the pinion angle. I do have a few kits pre-ordered that I have to get done, but otherwise, I could take an order for one now, and have it ready in two weeks.
I would do the install it on one more A body to make sure the fit is correct. Where should I bring my car?  awesome work. Tom
man that looks sweet  ...im gonna cruise over joes and eye it up in person.  i wish the amc market was bigger, id like something like that on my amx. i wonder how difficult it would be?  .......im definitly goin that rout when i build my dart
this is not some April fool gag is it?
definatley not.. there is no way i could photoshop the aches and tiredness i'm feeling today from yesterday...  .
oldkimmer
Looks like a great system, good pics......kim.........
dork.
 .. i'm serious.. i need a freaking nap or something..
oh bill, it was funny we were out at lunch today with jamie's parents and tyler says to me " man dad bill really took those bends fast, it was cool." i was laughing.. i hoped you were gonna give the car a beating when you took it out.... the only down side i see to that is that i think tyler is hooked on this stuff... man is this gonna cost me some money..
A13Dart
Great looking kit. Couple of questions for Joe or Bill. Do the additional spring perches line up under the frame rails, like where the mopar perf spring relocation kit perches go ? How much more tire clearance does the lower link have over a stock located leaf spring ? Could the lower link be offset and installed even closer to the frame rail ? Could the kit come with links that are .750 inch longer for those that want to install the rear housing back for tire diameter clearance ? How do you think this set up would work on the strip with slicks ?  Again , awesome looking kit. mike.
i know bills 275/50-17 tires (27.8 X 10.  mounting on a 17 x 8 rim with a 5.72 back space fit perfect on the back of my car.. and the wheel wells are stock.... i don't think the other perches are under the rail where they would be if mini tubbed but bill could answer that better then me..
Actually, I initially made it all using the inboard location. My dart had the inboard springs and I left the old perches on the axle, so worked it out so everything fit either way. Looking at the pics above, if you use the inboard location, the tabs for the upper links are between 2 of the ubolts. I can get links that are 1" longer, and you can adjust them 3/4" or so, so any length is possible - I kept that in mind when working it out - i know you need to go back an inch to fit 29.5's in there.... It wasn't intended for strip use, although it's more than strong enough. But the anti-squat characteristics are low compared to 4-link or ladder bars. With those systems, you end up with more than 100% anti-squat, but there's alot of roll-steer if you have alot of anti-squat, so I kept it low for more predictable handling. This system, if you move the lower bars to the top hole, will give you about 80% - not bad, but nothing near a drag race type of suspension. I do believe that's more than a leaf suspension though. Think of this - with proper tuning, this same arrangement of parts is propelling mustangs and drag radials into the 9's, so I'm not too concerned. Below the 11's, you'd probably have to add a strip type of sway bar - in a wheelstanding car, there will be alot of body roll off the line, which would have to be controlled. I gotta say Joe, Tyler was cool-headed - I only caught him grabbing the armrest on one turn  Yep...you're going to have trouble with him when he gets that licence
A13Dart
Thanks for the info Joe and Bill. I'm wondering if your kit might be the ticket for super stock classes in the 10 to 11 second zone. Yup, looks like the new perch is right under the frame rail, which would be cool for everybody that moved their springs in  [attachment deleted by admin]
6469mopar
WOW, THATS BAD A$$' NICE JOB BILL I'M HERE WAITING BY MY PHONE  [attachment deleted by admin]
sycboi
Every damn time I think I'm done spending money...
SuperBeast
