July 05, 2008, 06:45:34 PM
| | |-+  check out my new RMS rear suspension ..(pics)
Pages: 1 ... 3 4 [5] 6 Go Down Print
Author Topic: check out my new RMS rear suspension ..(pics)  (Read 19289 times)
Re: check out my new RMS rear suspension ..(pics)
« Reply #120 on: August 20, 2007, 05:52:46 PM »
i saw it at the nationals and its beautiful, maybe when i get the money
jess13
« Reply #121 on: September 13, 2007, 06:35:54 PM »
Bill,  maybe I missed it, but will this work for a early A body?  If not wouldnt part of the kit work & I could fab up the rest myself?  This the type setup I want under my 66 Dart.  Although I do plan to race the car I am more interested in a good all around handling with a fair leave at the track with DR's.  Looking at Joe's car leaving the line I already know what to expect with that part.  If not overpowered, it should supply a pretty good 60ft anyway.  My car will be a 6 speed with turbo so I want be doing major hard leaves anyway, the ET will come on down the track from the major MPH.  Drive in, turn a 9.50 is the goal.  But I will be driving on 2 to 300 mile trips with plenty of back roads involed at times.
I know 9.50's may sound like a bit of stretch in some ways, but with a turbo setup & the right motor combo its a breeze.  I can do it on springs, but really want that little bit better handling & fitting the right tire combo with the stock wheel wells.  WIth what you have going here, it looks like the perfect setup for my intent.  I am not sure how the 66 Dart wheel wells compair to the 67 up cars, but I believe the 275/50/17's should be a go.
Jess
nd2stopfastr
« Reply #122 on: October 13, 2007, 08:49:48 PM »
q: tn bill or joe, is there enough room to have 8.5" of clearance on the backspace with this kit? do i need to move the front mounts to acheive this? i plan to tub as much as needed and im using a 8.8 with a width 5/8 less than stock
« Reply #123 on: October 13, 2007, 11:08:32 PM »
i have 5.72 backspace and that close to the limit..  you would have to move the mounts inboard and you may be ok..  bull would know better though.
nd2stopfastr
« Reply #124 on: October 13, 2007, 11:23:33 PM »
thanks for the quick reply joe, great sig pic too =D
edit: did some further searching and calculations and figured this out  i'll be talkin to you soon Bill
austin9746
« Reply #125 on: October 22, 2007, 04:46:16 AM »
I was just wondering what i need to do to get info on purchasing this set up, I cant find it on the site and tried emailing throught the rms website but have not heard anything back.  Thanks in advance for the help.
« Reply #126 on: October 22, 2007, 07:38:41 AM »
  your phone works ok right?
right off the RMS site.
Our Daily Hours Are 9am - 6pm Eastern Time.
Phone - 570-443-7440
Our Current Mailing/Shipping Address is:
Reilly MotorSports, Inc.
2323 White Haven Rd.
White Haven, PA. 18661
64 Dart in a Donut
« Reply #127 on: November 06, 2007, 12:22:30 AM »
a couple people have asked with no answer, will it fit on an early a, or what i should be asking is if the distance between the frame rails, and the spring mounts are the same
« Reply #128 on: November 06, 2007, 04:19:24 AM »
I can't answer for bill but I would assume it wouldn't work because it was designed for a 67-76 abody as far as I know.
I don't suffer from road rage, I enjoy every minute of it.
My vehicles:
-1984 Dodge Ramcharger 318 auto 4x4 atc stock beast
-1968 Dodge Dart GT 6cyl auto buckets console work in progress
-1966 Bridgestone 90 Deluxe
-1946 Fargo 3/4 ton
Administrator
White Haven, PA
« Reply #129 on: November 06, 2007, 08:47:35 AM »
No, doesn't work in early A's - different width.
64 Dart in a Donut
« Reply #130 on: November 06, 2007, 11:16:41 AM »
would that be the only problem if it was used on the early a bodies. how far off is the width between the frame rails? and are you going to make a kit available soon.
Administrator
White Haven, PA
« Reply #131 on: November 06, 2007, 12:00:56 PM »
I wouldn't mind doing it, but I don't have an early a here, and time is very tight for new items at the moment. I'm sure I could get someone to bring an early a up to me, but I have some other pressing matters with new ideas that I'm commited to already. There's no way to know what could be off - for instance, the b-body frame rails at the rear are only 3/4" wider - however, they also kick up higher than the a's, so the crossbar I make now has to be in a totally different location to work out. Strange differences abound...
MomsR/T
3rd Gen HEMI Specialists
« Reply #132 on: November 06, 2007, 04:49:59 PM »
Joe, is your new sig picture a launch with the new rear suspension ? Either way thats a hell of a wheels up shot for a 12 second car ! Looks good Joe.
  yes that was the first time out with it... i was suprised how much different it launched.
you noted "different"
is this "different" in a good way, bad way or just a strange NEW way?
Just interested in your input please
http://i3.photobucket.com/albums/y72/RgrLee/IMAGE_007.jpg
Best 5.7 / 6.1 HEMI heads, cams, and long blocks..........Frank Racing Inc. www.frankracinginc.com or 877-fri-hemi
« Reply #133 on: November 06, 2007, 05:08:09 PM »
  better..  it used to squat some and pull the front wheel maybe an inch...    now the bumper almost hits the ground the front comes up more level and the wheel comes up probably about 3 inches...
« Reply #134 on: November 06, 2007, 05:12:13 PM »
  here it is with a full stock suspension....
  here it is with a stock rear suspension an alter-k up front.
« Reply #135 on: November 06, 2007, 05:19:30 PM »
  had a better picture of it launching now but can't find the damn thing.
64 Dart in a Donut
« Reply #136 on: November 07, 2007, 08:26:55 PM »
how much wider is the later a then the early
64 Dart in a Donut
« Reply #137 on: November 12, 2007, 01:22:40 AM »
did i scare everyone away, does anyone know how much wider is the distance between the framerails on the later a than the early a
Stroked GT
im right next to the Pacific, to be specific
« Reply #138 on: November 12, 2007, 04:19:00 AM »
beats me, but I want this bad, first the alterk up front, then this for the rear. man im never gonna finish this car  Grin think it'd be possible to put 255-45/20 tires on 20x9 rims out back without hackingor mini tubbing the wheel wells??
trying to reinvent the Dart, one dog dish at a time - Car Domain Page
Planned Upgrades: EFI - HID - AlterK - TKO - GPS - DUBs
« Reply #139 on: November 12, 2007, 07:58:57 AM »
well page one joe said the size of bills rims and tires and they were in his cars stock wheel wells:
Quote
i know bills 275/50-17 tires (27.8 X 10.Cool mounting on a 17 x 8 rim with a 5.72 back space fit perfect on the back of my car..  and the wheel wells are stock....
so I don't see why a 20" rim with a 255-45/20 wouldn't fit. Personally you should mini tube it because bill had said if you minitub it and move the spring perches in you can fit a 305 tire in there:
Quote
Just inboard the front mounts, just like you had leaf springs. It works the same - I actually designed it with the links inboard, and later tried the stock location.  I'm putting 305/35/18's on, and I should actually have a bit of clearance on the inside.
  It's alot more difficult to do the tubbing than it is to move the front perch inboard - move them in while you're grinding the wells and you'll have lots of room.
just out of curiousity what wheel have you decided to run and what kind of offset do you have?
I've changed my mind on rims again and am looking at the american racing Razor
18x9 with these specs:
offset +12
backspacing 5 1/2
My vehicles:
-1946 Fargo 3/4 ton
Stroked GT
« Reply #140 on: November 16, 2007, 01:58:57 AM »
Quote
offset +12
backspacing 5 1/2
im not sure if that was referred to me, but if so, i was looking at Charger SRT-8 wheels, like the photochop in my sig. I have to check the offset i dont know what it is. I just won a wheel on ebay that im going to use for test fitting, etc. If I dont like the look im going to resell it. i dont want my car to look all donked out
« Reply #141 on: November 19, 2007, 01:03:32 AM »
let me know how that charger wheel works out I think it's close to the sizes I'm looking at running.
Just out of curiosity this is more of a question for bill but I was wondering if I ordered the kit without powdercoating would it end up cheaper?
My vehicles:
-1946 Fargo 3/4 ton
Administrator
White Haven, PA
« Reply #142 on: November 19, 2007, 10:22:57 AM »
No, we ship them bare. It was holding up the show an extra week for the powder coat, and half the people getting them want some other color... Many of them are in full-on projects, so they want to paint the upper crossbar along with the car color.
By the way, an update....
The rear kit now fits perfectly with TTI 2.5" tailpipes - so it's now fully adjustable coil-over or air, stock gas tank, off the shelf tailpipes...I'm pretty excited about it actually LOL  Will work with 8.25, 8.75, and also a 9". The dana center casting is wider, so with that rear I'd still have to do the old style that doesn't allow the tailpipes.
Joe - we have to mod yours in the spring, it worked out sweet.
Dave_n_68_383S
« Reply #143 on: December 27, 2007, 02:04:59 AM »
Hold the phone Bill !!! You have gas tank and TTi pipes.. 2.5. I suppose 3" is just beyonf the envelope ?
golferjohn
« Reply #144 on: December 27, 2007, 02:24:30 AM »
Quote
offset +12
backspacing 5 1/2
Hey, how do you photo chop different tire/wheel options?
I would very much like to sample different combinations before I commit the cabbage
Thx, J
Administrator
White Haven, PA
« Reply #145 on: December 27, 2007, 11:43:16 AM »
Quote
Exactly...well, it's possible the 3's would fit, but in the car I used with air ride, the suspension would go fully compressed without hitting the 2.5's - it looked to me like the 3's would just be too fat to comfortably fit, although I don't have a set here so I can't say for certain.
I was going to stick up some pics, but I forgot to get em off the camera. I'll put some up this evening when I get home.
GTS Cowboy
« Reply #146 on: December 29, 2007, 11:30:10 AM »
Amazing and very innovative...Bill your somethingelse.Extremely profesional,I'm sure this is on its way to a national mag as a feature article...I cant wait! Popcorn...............Dam it,as if I'm not broke enough now I gotta build a modified Dart!!!                                bbd sign
Life begins @ W.O.T.
Dono
Want what you have..........
« Reply #147 on: February 29, 2008, 07:26:37 AM »
Bill How do I put in an order?  Andy is comming up very soon and if you could ship to him that would be great.
IM me let me get you some money.
Don.
Stroked GT
« Reply #148 on: March 02, 2008, 04:53:24 PM »
Quote
offset +12
backspacing 5 1/2
Thx, J
sorry i just saw this now. if your familiar with photoshop, it works with layers. i get my first photo of the car im going to use as the first layer, check how wide the wheels are in the pic, and then i get a pic of the new wheel i want and resize it so that the wheel is close to the one in the original pic. then i just paste it over the original, you can move it over the original wheel and you can just erase whatever is surrounding the wheel, the original image underneath will still be there as you erase whatever you want from the new wheel you pasted
blasphemous
« Reply #149 on: March 13, 2008, 03:57:49 AM »
What an awesome looking setup.  Looks like what the GM A-bodies are running under them.
Pages: 1 ... 3 4 [5] 6 Go Up Print
