October 12, 2008, 10:11:23 AM
| | |-+  brake line fittings
Author Topic: brake line fittings  (Read 151 times)
west
brake line fittings
« on: April 09, 2007, 05:04:18 PM »
do you ever use any type of teflon tape or some kind of tape to prevent leaks?i have a fitting that is giving me grief and am trying to avoid replacing the line it's attatched to.
Birdius Rapidus
Re: brake line fittings
« Reply #1 on: April 09, 2007, 06:06:37 PM »
If it is a NPT then yes. If is is a flare fitting then no. Also if trying to reseat a flare on a used inverted flare fitting or hose, the seating surface gets mated and won't seal. the fitting or hose end may have to be replaced.
