Topic: Where to mount aftermarket fuse panel? (Read 223 times)
Ok started laying out my wiring harness today but I'm not for certain where I want the fuse panel mounted under the dash, those with aftermarket harnesses where did you mount yours? I wanted to mount it in the trunk but there's not really enough slack without splicing in more wire so under the dash it goes..It's an EZ Wiring Harness off Ebay....
Ryan
do you have a heater? also, if you have the cowl vent opened up you can cover the big round hole with sheet metal and it would make a nice big flat surface for mounting somthing. i put mine here,it could go higher but i wanted easy accesability.
Yeah I'm keeping my heater, all the underdash componants are staying, except for aftermarket gauges and wiring...
Ryan
jet-taz
the glove box would be good. easy to get at and weather proof.
Thanks James, didnt think of that one, maybe lose the box part itself and put a plate in with the panel mounted to it so it's right there when you open the glove box door! As long as they gave me enough slack I might do that!...This harness is well made but some more slack would have been nice. Ryan
340dart
just mounted my 2 additional fuse blocks to the heater fiberglass box up under dash so they cant been seen but easy to get too, when installing remove glovebox to install.
mopar_eric
BBD BABY
I put mine behind the driver side kick panel. Makes it stick out just a bit but it's really easy to get to. Can pop it out with the door sill on no problem.
Eric
i am mounting mine on the trans tunnel under my custom console im working on, a quick access panel and it all right side up and easy to fix, i thought about the glove box, but i actually use it
