November 23, 2008, 08:13:18 AM
| | |-+  Mancini, Lower Control Arm Stiffening Plates
Author Topic: Mancini, Lower Control Arm Stiffening Plates  (Read 1103 times)
nothingbutdarts
« on: April 21, 2007, 08:17:21 PM »
How about an opinion on the lower control arm stiffening plates Mancini Racing sells? Is it worth doing it to the arms when doing the  bbd sign  thing?
  Or not?
69 Swinger 340
Soon to be 69 426 Dart
80 Crew Cab gas hawg
01 DIESEL Hauler
   Bailey, Colorado
Joe-Dokes
Re: Mancini, Lower Control Arm Stiffening Plates
« Reply #1 on: April 21, 2007, 09:30:25 PM »
Firm Feel also recommends the stiffening plates if you plan to install a front sway bar.  Considering how poor the Mopar front end is, I think it couldn't hurt and might help a great deal.  Think about it, if you install urethane bushing, a nice sway bar, and tubular upper control arms, you basically throw much of the advantages away when the Lower Control Arm deforms under load.
Considering that they are 22.95 plus tax and shipping I think it would be a good investment, particularly if you are a skilled welder and can install them yourself.
As a side note, I would inspect your suspension components thouroughly, Hot Rod built a hemi car about ten years ago and found cracks in some suspension components.  They had them all bead blasted and magnafluxed, on a drag car that might see 150 mph, it seems to be cheap insurance.  For a cruiser, a good cleaning and careful inspection might suffice.
Best of Luck
Regards
Joe Dokes
dartracer
Strasburg CO.
« Reply #2 on: April 21, 2007, 10:12:48 PM »
Just get some steel and make your own, Not very hard at all.
« Reply #3 on: April 21, 2007, 10:31:46 PM »
Not worth the hassle for $25.00 to make your own. I bought them and had them welded before changing up to an alterkation. Gave them to a friend. The important part is to postion the holes in them to where the torsion bar adjustment bolt is so you can adjust the bolts (don't forget the pre-load). The other thing is if there is any play, side to side, on the torsion bar socket assembly clamp the sides of the LCA down until the play is eliminated then weld them   Grin.
andyf
« Reply #4 on: April 21, 2007, 11:37:27 PM »
I highly recommend them!  Actually I've been shocked how many of those kits we've sold since I started making them.  I sell a few hundred plates every year.  I never thought a weld on part would sell like that but they do.
wild383
Wild383@live.com
« Reply #5 on: April 22, 2007, 05:35:46 PM »
I had Bill "AAOUTLAW" add the plates to my LCA's and he did a great job. I like the extra stiffness that they bring to the control arms.
oldkimmer
« Reply #6 on: April 22, 2007, 05:53:51 PM »
Has anybody installed these while the arms are still in the car?  Do u welder guys+gals suggest a mig or the good old arc?.........Kim....
nothingbutdarts
« Reply #7 on: April 22, 2007, 08:36:33 PM »
   Do they come already comformed to the LCA or do you have to bend them to fit the curves?
69 Swinger 340
01 DIESEL Hauler
   Bailey, Colorado
« Reply #8 on: April 22, 2007, 08:49:08 PM »
You bend them, nothing to it. I just started in the middle with 2 visegrips and worked out to the ends.
« Reply #9 on: April 22, 2007, 09:18:17 PM »
How poor the Mopar Front end is?HuhHuhHuhHuhHuhHuhHuhHuh
The best handling front end of the big three from the musclecar era.
That said, I also recommend them, but you can add a sway bar tab to them for a nice one-piece solution to non-sway-bar-tab LCAs.
nothingbutdarts
« Reply #10 on: April 22, 2007, 10:39:18 PM »
                       thank you
69 Swinger 340
01 DIESEL Hauler
   Bailey, Colorado
Two Lane
« Reply #11 on: April 26, 2007, 06:40:33 PM »
Excellent question!!  Smiley
« Reply #12 on: April 26, 2007, 07:01:44 PM »
I didn't install in the car, but I don't see any reason why you couldn't.
« Reply #13 on: April 26, 2007, 07:44:09 PM »
you should jack up the front end and let the control arms hang to take any pressure off them, then weld them, otherwise they might warp and bend.
Prodart
« Reply #14 on: April 26, 2007, 07:44:27 PM »
The only restraint to on car application would probably be make sure there's no wieght on the arms when you put the heat to them. Smiley
« Reply #15 on: April 26, 2007, 07:52:49 PM »
  agree I think I just heard an echo...   Grin
Prodart
« Reply #16 on: April 27, 2007, 08:55:20 AM »
You just type faster then i do !!!! lol lol lol
« Reply #17 on: April 27, 2007, 10:37:26 AM »
by 18 seconds, about as fast as a Ram does the 1/4 miles.
Two Lane
« Reply #18 on: April 27, 2007, 12:10:21 PM »
Thanks for the helpful replies!  Smiley
74swinger
« Reply #19 on: April 27, 2007, 05:18:12 PM »
I made my own as well.  Not hard at all.
The price goes up big time for the Northern igloo dwellers such as myself   Grin
« Reply #20 on: April 27, 2007, 11:35:21 PM »
Use the left over 2" flat bar from your subframe connectors.
See the T bar bolt. I forgot that the bolt sits inside the LCA when adjusted. The carbide rotary file ovaled the hole.  brain fart
took about an hour for both.
urchinhead
San Francisco, CA
« Reply #21 on: April 28, 2007, 12:00:03 AM »
Tom -
  did you fabricate those sway bar mounts from scratch, or did you buy them and weld them on?
« Reply #22 on: April 28, 2007, 08:16:17 AM »
if you do them on th ecar you have to watch you dont melt your lca bushings.
« Reply #23 on: April 28, 2007, 10:03:27 AM »
Wow, those are some beautiful welds. Mine look like chicken shit.
nothingbutdarts
« Reply #24 on: April 28, 2007, 10:46:44 AM »
     agree   On the welds that is! They look very strong.
69 Swinger 340
01 DIESEL Hauler
   Bailey, Colorado
« Reply #25 on: April 28, 2007, 10:52:11 AM »
Thanks guys. Those are the factory sway bar brackets. I have repaired most of the factory welds on the car. Those are true "hammered dog shit" welds.
The steel  bends without heat. Tack one end, hammer it down, tack it another inch and repeat.
74swinger
« Reply #26 on: April 28, 2007, 11:35:12 AM »
 agree  Did mine soft of the same, but I pre-rolled them to get the shape close.  The heat of welding makes it easy to get it nice and tight.  I was lucky and had access to a metal roller.  Also, I did not use 1/8" plate - I used 0.050" thk cold rolled plate (left overs from other stuff).  Don't need to go crazy with the weight.
I did not fix any iof the factory welds, because those welds tend to look better than my "chicken shit".  Just when I think I did some nice welding, Tom posts another photo.....   \/][
Can you come North and weld my stuff up?  I suck at this welding gig.............
You do great work and you should be very proud of your accomplishments.     Cheers
« Reply #27 on: April 28, 2007, 12:31:01 PM »
YOU CAN AGREE ON MY CHICKEN SHIT WELDS TOO!   Grin
« Reply #28 on: April 28, 2007, 12:32:04 PM »
that has to be a TIG weld?  Huh
« Reply #29 on: April 28, 2007, 08:54:42 PM »
No it is my Mig. I'll use my tig torch on the 8pt roll bar.
'74swinger: I'll come up north and weld for all the Elsinore and jelly doughnuts that I can consume.  Grin
Pages: [1] 2  All Go Up Print
