Topic: A-body Dart 440 BB Shock tower brace (Read 758 times)
hyperdart
Does anybody have a pictures of, or made a shock tower brace to support the shock towers from flexing inward. ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif) ..As i had to cut out the front inner part of the fender well away to use the fenderwell Hooker Supercomp Headers. In so doing i have lost some shock tower support and now the upper shocks have a little flexing....I heard of guys with Big Block in A-body, Darts, Dusters,Baracuda's.ect. Using a shock tower support or as in the import world called: a strut tower brace...I have a six point cage; frame connectors...But don't want to go through the fire walls to weld bars in, as i won't have the space to remove the headers, if need be...Please help guys/Gals as the flexing cant be good for handleing with a 600 Hp  Engine going down the street...As this car is only a pro street car and not a full out race car as some may think it to be.....Thanks for any assistance you all may provide.  Chow,Brian Beck.
GLENNP
I don't think having the inner aprons cut out without having a bar at least from the engine bay side of the firewall is a good idea. Your frame rails now have no vertical support. The upper shock mount could be made with a U shaped tube welded to the frame rail, but I would worry about rail support first. The rails were designed to work with all the engine bay sheet metal.
Online
You cut out the front? Should be the rear for the headers. If your cut was only what was required you're probably ok. A solution to the flexing might be a pair of side bars from the shock tower down to the frame.
GLENNP
Oops didn't read front. There are a lot of pics in the gallery. I have 6-8 of them saved to my favs.
dusterdarryl
you may have to go thru the fire wall but it makes it stiff as can be, probly better than stock
Blue
If you mount those bars about 6" higher on the rear (on the heater plenum) you can get fenderwell headers in and out no problem, did mine that way.
dusterdarryl
I dont have any problems with my Hooker f/exits, infact they are a snap to put in & out with a RB engine in the car
Midnight Special
Heres a few additional pics
The MIDNIGHT SPECIAL RACING FamilyWichita Kansas AreaNHRA/SFI Tech InspectorNHRA Division V
