Topic: 1968 satellite wiring (Read 191 times)
68GTS383
Does any one have a wiring diagram to install a Mopar Performance electronic ignition with the orange box into a 68 Sport Satellite 318 auto non A/C? I am trying to clean up a MESS! Thanks,Ashley!
thebankerstoy
Here is the wiring diagram for the Mopar Performance electronic ignition conversion kit. Let me see if I can down load the stock wiring harness for your car so I can post it here. If not, I should be able to e-mail it to you if that is ok.
Richard
68GTS383
Her is the wiring diagram for the Mopar Performance electronic ignition conversion kit. Let me see if I can down load the stock wiring harness for your car so I can post it here. If not, I should be able to e-mail it to you if that is ok.
Richard
Will I have to change the voltage regulator? Dual field or single field alternator? Ashley!
west
i just did a conversion and my wiring diagram is different on mine it says to connect the blue wire to the keyed hot side of the ballast resistor,yours has it on the other side,and the red wire you have is not mentioned in my instructions. this is the mopar kit for smallblockpart #dcf194cc
moparts can kiss my ass
thebankerstoy
Ashley,
With your Mopar Performance conversion kit, you should also upgrade to the constant output voltage regulator, Mopar Performance part #P3690732, along with the dual field alternator. I have the stock wiring diagrams for your car, but it would be better if I could e-mail them to you, as they will be easier to read that way. Please let me know if that is ok and I'll take care of it for you.
Richard
