Topic: weak spark (Read 481 times)
1972 dart
hey you guys, i have a little problem with the dart.
there's only 6 volt on the coil when starting and a very weak spark,could it be the problem of no firing the cilinders?
do i need 12 volts when starting and about 9 when idling?
what could be the problem,i changed coils with no luck.....
thanks,
alfred
resistor or ecu
oldkimmer
 .....or possibly a bad ign switch......kim.......
1972 dart
thank u guys,resistor is new..but could be out again...
ecu,i don't know...how to find out if the ecu is out,i do not have another one lying around?
alfred
mopar_eric
BBD BABY
Is this a mopar distributor? what kinda ignition? Almost every mopar ignition I replace with MSD needs 1) very solid power and ground connections from the battery to the MSD 2) air gap reset to .008. It makes a huge difference in the signal. I had a dist that wouldn't even fire at like .015
HTH
1972 dart
HTH
hi,it's a electronic ignition with a black ecu from mopar. air gap is 008 it did run a week ago,so couldn't be a big problem i think  but i can't find it
1972 dart
ok,the dodge is running now,i tried another ecu.
can i use evry ecu,orange,gold?
i have a black ecu ( 5 pins ecu and 4 pin resistor)
alfred
