September 07, 2008, 07:55:47 AM
| | |-+  weak spark
Author Topic: weak spark  (Read 568 times)
1972 dart
weak spark
« on: May 03, 2007, 01:38:54 PM »
hey you guys, i have a little problem with the dart.
there's only 6 volt on the coil when starting and a very weak spark,could it be the problem of no firing the cilinders?
do i need 12 volts when starting and about 9 when idling?
what could be the problem,i changed coils with no luck.....
thanks,
alfred
55robert@bellsouth.net
Re: weak spark
« Reply #1 on: May 04, 2007, 09:31:39 AM »
resistor or ecu
oldkimmer
Re: weak spark
« Reply #2 on: May 05, 2007, 02:58:00 PM »
 agree.....or possibly a bad ign switch......kim.......
1972 dart
Re: weak spark
« Reply #3 on: May 07, 2007, 11:01:25 AM »
thank u guys,resistor is new..but could be out again...
ecu,i don't know...how to find out if the ecu is out,i do not have another one lying around?
alfred
mopar_eric
BBD BABY
Re: weak spark
« Reply #4 on: May 07, 2007, 06:57:12 PM »
Is this a mopar distributor? what kinda ignition? Almost every mopar ignition I replace with MSD needs
1) very solid power and ground connections from the battery to the MSD
2) air gap reset to .008. It makes a huge difference in the signal. I had a dist that wouldn't even fire at like .015
HTH
1972 dart
Re: weak spark
« Reply #5 on: May 08, 2007, 05:11:32 AM »
HTH
hi,it's a electronic ignition with a black ecu from mopar.
air gap is 008
it did run a week ago,so couldn't be a big problem i think Dunno
but i can't find it
1972 dart
Re: weak spark
« Reply #6 on: May 12, 2007, 08:35:35 AM »
ok,the dodge is running now,i tried another ecu.
can i use evry ecu,orange,gold?
i have a black ecu ( 5 pins ecu and 4 pin resistor)
alfred
