Topic: 1972 dart disc brake swap from 78 volare wagon (Read 332 times)
yellowabody
will 1978 volare 6cyl wagon disc brakes fit my 72 dart ? would also like to see if the rearend fits the car has the small bolt pattern wheels now and drum brakes
dartracer
The discs will work just need to get the 73-76 Abody upper control arms,or Bills uppers. The rear end is a little to wide for for a Dart. Dave
mopar_vince
Look in the tech pages under "Spindle Interchange Info".Good article,should help.
yellowabody
thanks for the info why is the rear to wide it measures 52 inch from backing plate to backing plate just like the dart? is the spring perch the problem if so i can change that. also would ya know is the 10 bolt dart a 8.25 ring gear ? /
