Topic: wheel pattern (Read 478 times)
1972 dart
hey people,what is the wheel pattern on my 72 dart,is it 5x4? some people say it is 5 x4.5  thanks, alfred
abodyjoe
a 72 should still have a 5 on 4 bolt pattern. unless someone changed it along the way..
1972 dart
quick answer,thanks  i have to measure to be sure because i want to change to rallywheels. alfred
bbscamp
make sure you measure the "circle" and not stud to stud. If you go stud to stud, the 4.5" pattern will measure 4.25.
1972 dart
can u explain that,with a drawing?
1972 dart
bbscamp
see how they went to the back of the hole....you pick up the 1/4 you lost by measureing the back side of the stud. It only works for 1/2 studs though.. the circle is the circle that the studs line up on. same difference....
1972 dart
it is 4 inch,so now i'm sure that the rallywheels i want to buy will fit.
thanks.
moparrr07
when measuring on a 5 lug as they have said, you go center stud, to other side of stud across,
5 studs are the only way you do this, 4, 6 and 8 you measure center to center
50% custom interior
1972 dart
ok thanks guys,
i got the wheels now and they have to be sandblasted and repainted.
now i want to know what the right color of the wheels is,so i need your help one more time.
thanks,
alfred
wild383
Check out Eastwood Co. they have the Argent gray paint that's correct for the ralley wheels.
1972 dart
thanks,that will do.
440WIP
You can order Argent Wheel Paint from your Dodge dealer, P4529876. It sprays on really light, so be very careful about the undercoat you use. Daryl
