Topic: sealer and sound deadener (Read 300 times)
Yellow
I want to seal and apply some sort of sound and thermal protection on the Demon, what has anyone used sucessfully? Dynamat?. Etc. I plan on adding aftermarket air con to the car and a decent sound system. should i spray undercoat and then the dynamat type stuff. Also, should i apply something to the bottom of the pans and inside the doors, how about the top, or is this overkill.
Roger
Yellow
west
just remember at 5 -6 oz. a sq. foot the weight adds up quickly.I'll prob. put some on the floor and thats it.
70 Dustpan
They say for best results apply it to at least 75% of the panels. This is floors, doors, 1/4 panels, roof, firewall.
Hey, I'm a God again!
Yellow
Well, West, i'm not concerned with weight, within reason, just want a nice quiet ride with the air on and the tunes playing, this won't be a balls to the wall type car, just a peppy cruzer. ( by the way, that's also the name of the guy that roofed my house :-), Thanks for warning though.
Roger
Capt Jack
Ive heard good things about Hushmats. thermal and sound deadener. self adhesive. a lot of audio guys swear by em. supposedly they go a long ways towards quieting interior noise while rolling. Im considering it myself, but Ive also seen (something like it) at swap meets but without adhesive....for hella cheaper. a few 3M glue spray cans and youre set. http://hushmat.com/
440WIP
I've got some sound deadener that I bought for one of my Dusters. I belive the concept is great, but after all the work it took/is taking, to get the rust out because of trapped moisture in the carpets and seam sealed areas, I'm really reluctant to put it in. I can sure appreciate the quiet factor that it will add - but I just can't get over all the hard work - and I do not want to have to do it all over again down the road. This is just me thinking out loud before I do it. Daryl
70 Dustpan
Well if you prep the metal right first then that's not a problem. I cleaned all the floor boards, firewall, and trunk with a wire wheel then sprayed it all with Por-15, then did the seams, and then painted it all. A big part of it is to also get your car all sealed up tight so you don't get water in it in the first place.
