August 07, 2008, 09:17:35 PM
| | |-+  sealer and sound deadener
Author Topic: sealer and sound deadener  (Read 324 times)
Yellow
« on: May 20, 2007, 07:34:59 PM »
I want to seal and apply some sort of sound and thermal protection on the Demon, what has anyone used sucessfully? Dynamat?. Etc. I plan on adding aftermarket air con to the car and a decent sound system. should i spray undercoat and then the dynamat type stuff.
Also, should i apply something to the bottom of the pans and inside the doors, how about the top, or is this overkill.
Roger
Yellow
Re: sealer and sound deadener
« Reply #1 on: May 20, 2007, 08:11:16 PM »
May have found something, but personal experience would be welcome.
Roger
http://www.b-quiet.com/
« Reply #2 on: May 20, 2007, 08:26:58 PM »
just remember at 5 -6 oz. a sq. foot the weight adds up quickly.I'll prob. put some on the floor and thats it.
Sacramento CA.
« Reply #3 on: May 20, 2007, 08:40:28 PM »
They say for best results apply it to at least 75% of the panels. This is floors, doors, 1/4 panels, roof, firewall.
Yellow
« Reply #4 on: May 20, 2007, 08:42:20 PM »
Well, West, i'm not concerned with weight, within reason, just want a nice quiet ride with the air on and the tunes playing, this won't be a balls to the wall type car, just a peppy cruzer. ( by the way, that's also the name of the guy that roofed my house :-),  Thanks for warning though.
Roger
« Reply #5 on: May 20, 2007, 11:28:37 PM »
Ive heard good things about Hushmats.  thermal and sound deadener.  self adhesive.  a lot of audio guys swear by em.  supposedly they go a long ways towards quieting interior noise while rolling.  Im considering it myself, but Ive also seen (something like it) at swap meets but without adhesive....for hella cheaper.  a few 3M glue spray cans and youre set.
http://hushmat.com/
a pirates life for me
440WIP
« Reply #6 on: May 21, 2007, 06:16:40 PM »
I've got some sound deadener that I bought for one of my Dusters. I belive the concept is great, but after all the work it took/is taking, to get the rust out because of trapped moisture in the carpets and seam sealed areas, I'm really reluctant to put it in. I can sure appreciate the quiet factor that it will add - but I just can't get over all the hard work - and I do not want to have to do it all over again down the road. This is just me thinking out loud before I do it.
Daryl
Sacramento CA.
« Reply #7 on: May 21, 2007, 07:27:27 PM »
Well if you prep the metal right first then that's not a problem. I cleaned all the floor boards, firewall, and trunk with a wire wheel then sprayed it all with Por-15, then did the seams, and then painted it all. A big part of it is to also get your car all sealed up tight so you don't get water in it in the first place.
