July 05, 2008, 06:19:17 PM
| | |-+  aftermarket wiring harness
Author Topic: aftermarket wiring harness  (Read 439 times)
Yellow
« on: May 24, 2007, 01:12:50 PM »
Besides Painless, who makes a complete wiring harness for a 71 Demon (A body)
Roger
6469mopar
JACKSON, NJ
Re: aftermarket wiring harness
« Reply #1 on: May 24, 2007, 01:44:30 PM »
 Try www.E Z WIRING.com
Duster Five-O
Port St. Lucie FL
« Reply #2 on: May 24, 2007, 03:55:09 PM »
 agree
Good quality at an unbeatable price.
http://www.ezwiring.com/
A God on the previous board.
moparrr07
working on custom console
« Reply #3 on: May 24, 2007, 10:23:52 PM »
Ron Francis wireing
brakes, 11 3/4
60-0: 105 ft.
cornering gs: estimate: .90
50% custom interior
Ryan (Strange246)
Merrimack NH
strange246 strange2462000
« Reply #4 on: May 25, 2007, 01:39:29 AM »
agree
 agree  I got mine there too, not installed yet but just looking at it, it's good quality, I think mine was $130?
Ryan
Dr. Hunter S. Thompson
cu440da
Saint Paul, MN
« Reply #5 on: May 25, 2007, 12:31:23 PM »
They just bumped the price up about $15. As always, just before I plan on buying it.  Roll Eyes
'67 Notchback- 12.88 @ 109mph
318_Magnum
Josh Vicini, Phoenix
UndividedUS UndividedUSA
« Reply #6 on: May 26, 2007, 05:24:09 PM »
Figures. I was just about to get mine too.
So do you guys think the EZ harness is as good as the Painless harness?
'99 Dakota Sport: 318 Magnum/NV3500/9-1/4
'72 Demon: 340/727/8-3/4
'69 Barracuda Fastback: 400/727/Dana 60 Proj.
'76 Dart Sport: 360/904/8-3/4 Proj.
Ace
« Reply #7 on: May 27, 2007, 11:43:55 AM »
Yes, I've had my hand on both, and they were almsot identical.  They installed the same, other than the EZ kit had more circuits for less money.  Cheesy
Ballz Deep Racing
Where Enough is NEVER Enough
www.midamericamusclecar.com
duster73
« Reply #8 on: May 27, 2007, 10:44:50 PM »
 agree
fstfish66
« Reply #9 on: May 31, 2007, 02:18:39 AM »
EVANS will re build your factory wireing harness to lok correct,,but not cheap,,,
i am currently collecting things to redo my b cuda,,encluding  new wiring,,, EZ, PAINLESS,, are all about the same,,
they are all geared to GM clolr coding,,and also to a 1 wire alternator set up,,,they have no plugs that are even close to a mopar plug, they wil tell you ,,that the plugs cant be gotten,,mopars  by crane has some orignal fitting repoped plugs,,
I  am going with  RON FRANCIS wiring,,go to there web site fil out a page you will get a new free catolog,,,
here is why i picked RON FRANCIS,,there system is the most expensive system,,but not as expensive as EVANS,,,EVANS looks factory correct,,,
RON  FRANCIS,, has a kit geared to mopar,,ford,chev,,not a generic kit,,,if you use a electronic ignition,,,you probably have up graded your charging system,,to the dual wire  altenator and voltage regulator,,RON  FRANCIS  has a kit geared to that,,but they use a ford voltage regulator,,they say it works with all MOPAR,FORD,GM,, and you can buy it off the shelf,,,you can get it for points,,electronic,,or after market such as MSD,,he will also include a diagram to hook up to your factory sterering column,,with no guessing,,, check out there web site,,then talk to the others,,,hope this helps,,,
1966 barracuda blown 340 4 speed tubbed 33x22
1940 dodge street rod hemi with A/C
2002 cummins ram dailey driver
