Topic: aftermarket wiring harness (Read 500 times)
Yellow
Besides Painless, who makes a complete wiring harness for a 71 Demon (A body)
Roger
6469mopar
Try www.E Z WIRING.com
Duster Five-O
A God on the previous board.
Ron Francis wireing
 I got mine there too, not installed yet but just looking at it, it's good quality, I think mine was $130? Ryan
They just bumped the price up about $15. As always, just before I plan on buying it.
'67 Notchback- 12.85 @ 109mph
318_Magnum
They just bumped the price up about $15. As always, just before I plan on buying it. Figures. I was just about to get mine too. So do you guys think the EZ harness is as good as the Painless harness?
xxxxx  xxxxx 72 Demon 340/727/8-3/4 69 Barracuda Fastback 400/727/D60 76 Dart Sport 360/904/8-3/4 04 MazdaSpeed MX-5 Turbo, 6-Speed, Boost Controller, Intake, TB Inlet, Comp. I/O Pipes, DP, BOV, o2 Mod, FMIC & More
Ace
They just bumped the price up about $15. As always, just before I plan on buying it. Figures. I was just about to get mine too. So do you guys think the EZ harness is as good as the Painless harness? Yes, I've had my hand on both, and they were almsot identical. They installed the same, other than the EZ kit had more circuits for less money.
fstfish66
EVANS will re build your factory wireing harness to lok correct,,but not cheap,,, i am currently collecting things to redo my b cuda,,encluding new wiring,,, EZ, PAINLESS,, are all about the same,, they are all geared to GM clolr coding,,and also to a 1 wire alternator set up,,,they have no plugs that are even close to a mopar plug, they wil tell you ,,that the plugs cant be gotten,,mopars by crane has some orignal fitting repoped plugs,, I am going with RON FRANCIS wiring,,go to there web site fil out a page you will get a new free catolog,,, here is why i picked RON FRANCIS,,there system is the most expensive system,,but not as expensive as EVANS,,,EVANS looks factory correct,,, RON FRANCIS,, has a kit geared to mopar,,ford,chev,,not a generic kit,,,if you use a electronic ignition,,,you probably have up graded your charging system,,to the dual wire altenator and voltage regulator,,RON FRANCIS has a kit geared to that,,but they use a ford voltage regulator,,they say it works with all MOPAR,FORD,GM,, and you can buy it off the shelf,,,you can get it for points,,electronic,,or after market such as MSD,,he will also include a diagram to hook up to your factory sterering column,,with no guessing,,, check out there web site,,then talk to the others,,,hope this helps,,,
1966 barracuda blown 340 4 speed tubbed 33x22 1940 dodge street rod hemi with A/C 2002 cummins ram dailey driver
