71 dart with just offset schakles and full call track suspension, with the small drum brakes wahts the largest wheel, backspacing and tire u can fit , including slicks , drag radials
Rear tire clearance varies depending on the year, as the coupe style cars have much bigger wells. Currently I only have specific info on the sedan/hardtop style. You can fit a 9.5" total width tire in the stock well. If you just move the springs inboard it will allow an 11" total width. If you move the springs in and the wheelwells into the frame you have 13.5" total width to play with. If you're building a car basically from the ground up, you might as well move the springs and wells while your car is apart. Lots of power does nothing if you can't get it to the ground.
