October 07, 2008, 03:56:13 PM
| | |-+  Copper Fuel line
Author Topic: Copper Fuel line  (Read 723 times)
74duster383
Copper Fuel line
« on: May 25, 2007, 10:34:40 AM »
Has anyone used copper for the fuel line?  I was going to get some braided line but I have about 25 feet of copper 3/8 line sitting on the shelf.  I don't even know if its within the rules or not for IHRA or NHRA.  Anyone know? And is it OK to use it.  Drag car only.
Thanks
Pete duster
73 Charger
74 Duster Drag car
MVRCorp
Re: Copper Fuel line
« Reply #1 on: May 25, 2007, 10:50:01 AM »
I wouldn't put that on my ex-wifes can. Seriously I think there is too much chance of the copper cold working causing a break. I doubt if it's legal.
65DartGT
Montville,CT
« Reply #2 on: May 25, 2007, 06:21:24 PM »
I've heard that copper is too soft and will erode over time causing leaks and gumming up your filters.
Long Island, NY
« Reply #3 on: May 26, 2007, 01:33:03 AM »
Copper is no good for fuel lines or much else on a car.
oldkimmer
« Reply #4 on: May 26, 2007, 03:05:43 AM »
NHRA NO  NO.............KIM............
kowski71400
« Reply #5 on: May 26, 2007, 08:56:33 PM »
i ran it on my car and the guys at the track never said anything. mabey they never noticed it. i would not run it again. it is a pain in the ass to bend, and it retaines heat. just use aluminun, it's so much easier, and it dosent hold the heat like copper.
bbscamp
Ehm.....B5 Blue am I?
« Reply #6 on: May 26, 2007, 10:25:51 PM »
My old Austin Mini had copper brake lines! Shocked
74duster383
« Reply #7 on: May 26, 2007, 11:40:11 PM »
Thanks for the replys, I won't be running the copper line.  The problem is there isn't anywhere with a reasonable distance that has steel braided line or aluminum.  So I have to order everything.  I don't know what I'll need as far as fittings.  Is 6an 3/8?  I believe the AN fittings are in 16th which would make 6an 3/8.  But I need to know for sure.  Does anyone sell a kit with line and fittings?
Thanks,
Pete
73 Charger
74 Duster Drag car
Capt Jack
« Reply #8 on: May 27, 2007, 01:40:10 AM »
yeah, summit has a bunch of ready made kits they sell.  different lengths, all the plumbing w/ braided.
http://store.summitracing.com/egnsearch.asp?N=700+4294924496+115+4294923362&NeXID=5
Prodart
« Reply #9 on: May 27, 2007, 05:02:19 AM »
yes 6AN = 3/8"
Grin
jamesdart
« Reply #10 on: May 27, 2007, 07:35:49 AM »
my 31 essex still has its original copper fuel and oil lines
karfixer
« Reply #11 on: May 30, 2007, 09:24:14 AM »
Just to muddy up the waters.... I work at my local school district and all the large busses have copper lines. I haven't seen any cracked lines, nor heard of any, and I can't see that as being an issue, the DOT and CHP would be all over that. This includes the fuel lines and the air brake lines. Trust me these things vibrate way more that any gas car you have ever been in. As far as bending, I've had to bend a couple of lines (fuel and air)and it was easier than steel to bend.
loiq
« Reply #12 on: May 30, 2007, 09:58:13 AM »
Other than wiring...
Birdius Rapidus
« Reply #13 on: May 30, 2007, 12:43:35 PM »
My powerstroke has copper fuel lines. I run stainless on my cars.
MVRCorp
« Reply #14 on: May 30, 2007, 09:18:02 PM »
Copper fuel lines?  \/][ "Well blow me down" as Popeye would say.......sorry no picture.
urchinhead
San Francisco, CA
« Reply #15 on: May 31, 2007, 01:24:54 AM »
I hope you didn't miss the argument over stranded vs. solid wiring!  cat fight
Crazy68Dart
« Reply #16 on: May 31, 2007, 06:53:06 AM »
Copper would take vibration much better than steel, it is a softer material thus less prone to cracking.  I am not sure how it compares to aluminum, but it may be a good compromise between steel and aluminum?
jyrki
« Reply #17 on: June 01, 2007, 05:41:39 AM »
Regular copper should be fine, but the heated copper lines that usually comes in coils, and is easy to bend and  form, is different. It will work harden from vibration, and can crack. I have used that in the past without any problems, but that's what all metallurgists say, it will crack from the vibration sooner or later.
sunsetdart
us4ever365@hotmail.com
« Reply #18 on: June 01, 2007, 06:54:03 AM »
#4AN=1/4".........#6AN=5/16"...........#8AN=3/8"........#10AN=1/2"............FYI
kuztomz
damn cats
« Reply #19 on: June 01, 2007, 10:35:09 AM »
I bought some brake line at Napa a while back, standard steel line but it's copper clad on the outside  Dunno maybe that's the kind of lines used on the busses?
lake worth, florida
55robert@bellsouth.net
« Reply #20 on: June 01, 2007, 10:45:17 AM »
  whoa dude. i always thought each 1/16" was one "an" size.
Long Island, NY
« Reply #21 on: June 01, 2007, 12:44:27 PM »
1/4 is 4.   6 is 3/8, 8 is 1/2, 10 is 5/8. Bob's right.
karfixer
« Reply #22 on: June 04, 2007, 09:19:11 PM »
Nope, pure copper- remember "the air brake lines" air brakes only run 130psi max. It's pretty soft stuff, relative to steel. The only line failure i've seen was due to a clamp that got loose and allowed it to rub through- no different than any other material.
sr71mopar
Santa Rosa, CA.
« Reply #23 on: June 04, 2007, 09:27:58 PM »
Tour buses are loaded with hard copper lines too. Fuel, A/C, oil, air, you name it. On some of the older ones with R22 refrigerant 300+psi is is an everyday thing.
Long Island, NY
« Reply #24 on: June 04, 2007, 11:18:22 PM »
Twenty two years ago, we made the fuel line from the pump to the carb from copper until the Coast Guard outlawed it. I'm sure they did it for a reason. The same bending tools will bend steel or aluminum, so why take a chance?
