October 06, 2008, 10:28:48 PM
| | |-+  how do you get hood hinges off a 73 Duster
Author Topic: how do you get hood hinges off a 73 Duster  (Read 221 times)
440darting
« on: June 04, 2007, 07:09:12 PM »
I bought a full pin on fiberglass hood for my 73 Duster, how do you remove the hood hinges off the car completely, need to have them removed so I can put the new pin on hood on
Poison_Dart
Re: how do you get hood hinges off a 73 Duster
« Reply #1 on: June 04, 2007, 07:42:35 PM »
it's not easy if you plan to leave the fenders in place, although with the right tool and limber wrist you may reach between the door and fender area and snap the push not off the pin then sometimes you can shake the hinge loose from the pin and pull it out through the top.
good luck..
Duster440
Blasphemous custom Duster
« Reply #2 on: June 04, 2007, 07:58:55 PM »
If you pull the splash shields (most likely covered in undercoat) you'll have more room to work. I have one hinge that will not slide straight off the pins - it will only come off at an angle with the fender removed. Magic curse words are of no use in this situation.
Preston H. - Duster project at: www.70Duster440.com
