October 07, 2008, 02:13:27 PM
| | |-+  correct master cylinder ?
Author Topic: correct master cylinder ?  (Read 260 times)
yellowabody
« on: June 10, 2007, 07:11:43 AM »
Hey everyone im replacing brakes on a 69dart gt with manual drum brakes i got a new master cylinder but i think its wrong the one on the car has a cap thats held down with a steel wire . also the push rod fron the brake pedal seems to not want to come out the new master has no pushrod and has a bolt on cover . does any have a clue on if that push rod comes out i pulled on it and ripped the guts out of the old master but the rods still stuck ?
Re: correct master cylinder ?
« Reply #1 on: June 10, 2007, 09:55:31 AM »
69 has the bolt to hold the cap on...theres a small o ring on the rod that holds it in the master. now that u have the guts ripped out, slice said guts open to reveal o ring on end of rod and it will pull out...if u dont cut too far, u should be able to reuse pushrod and o ring.
yellowabody
« Reply #2 on: June 11, 2007, 06:18:09 AM »
thanks for the help
« Reply #3 on: June 11, 2007, 03:24:12 PM »
