October 08, 2008, 03:50:10 AM
| | |-+  traction aid
Author Topic: traction aid  (Read 1136 times)
moparrr07
working on custom console
Re: traction aid
« Reply #30 on: June 23, 2007, 12:00:57 AM »
i read you can use brake line to make a really nice fender lip
brakes, 11 3/4
60-0: 105 ft.
cornering gs: estimate: .90
50% custom interior
Jim13
San Antonio, Tx
Re: traction aid
« Reply #31 on: June 23, 2007, 01:00:59 AM »
I measured those street tires and they are 28" tall and 10" wide at their widest.  The width of the actual tread is a little smaller.
The best time so far has been 12.96 at 104 with the 1.81 60'.
cu440da
Saint Paul, MN
Re: traction aid
« Reply #32 on: June 23, 2007, 10:02:04 AM »
we have 1" between leaf spring and sidewall of tires at closest pt., and on the other side we have 1/2" between fenderwell and sidewall closest pt.
It looks like you can't stick much wider of a tire in there, any chance you can go taller? That will get you a little bigger contact patch.
'67 Notchback- 12.85 @ 109mph
Dallas, TX
Re: traction aid
« Reply #33 on: June 23, 2007, 11:05:02 AM »
I did some measuring on some actual, mounted drag radials and found something interesting. M&H drag radials are narrower than the competition. I checked and the 275/60r15 would fit in the wheel wells of a dodge dart just fine, it seems that M&H tires are narrower in the sidewall than comparable tires in the 275 size. In fact the 275/60 M&H measured out the same as the 255/65r15 I used to have. This tire is actually slightly narrower in the sidewall than my 265/50 tires. If you stick these tires on a 7" wheel, then they will suck in another 1/2".
Tread Width: 8.8"
Section Width: 10.6"
Diameter: 28.0"
Circumference: 88.0"
Rim Size: 8.0"
Actual 275/60 tire:
http://www.mandhtires.com/product_videos/275_60_15.wmv
This is a 325 version of that tire:
Pages: 1 [2]  All Go Up Print
