July 09, 2008, 12:45:10 AM
| | |-+  PRessure bleed procedure
Author Topic: PRessure bleed procedure  (Read 338 times)
bbscamp
Ehm.....B5 Blue am I?
« on: February 06, 2006, 05:23:54 PM »
I read that when using a pressure bleeder with a disk front end, you need to hold open the metering valve.   On my 75 Dart, the propotioning valve has no visible metering valve -  or at least one to hold open.  If so....how?
thx
Dartsport
Re: PRessure bleed procedure
« Reply #1 on: February 06, 2006, 05:36:12 PM »
I have a pressure bleeder here at my shop. You should use 10 psi.  in pressure bleeder. I have never had to play around with the button on the proportioning valve. I usually pressure bleed from the farthest to the closest. Then I go over each wheel once or twice , by having an assistent hold down on the brake pedal while I open and close each bleeder.
