September 07, 2008, 08:19:33 PM
| | |-+  trunk mount battery install
Author Topic: trunk mount battery install  (Read 301 times)
408 dart
« on: June 28, 2007, 12:35:32 AM »
if i run positive wire inside car on drivers side, how do i get it through floor to starter or to selonoid
Re: trunk mount battery install
« Reply #1 on: June 28, 2007, 12:53:48 AM »
I ran it under the drivers kick panel and used one of the long abandoned holes in the firewall.  it had a rubber plug in it, near the steering column left side.  sealed it up good after using some heavy wire ties on each side to keep it located but away from sharp metal edges
a pirates life for me
jacks62440
« Reply #2 on: June 30, 2007, 04:11:00 AM »
Why not keep it outside Huh  You can just run it through grommets . Something else you could do is put a master disconnect switch under your seat as a anti theft device, Also a handy shut off. I put my cable through a hole in my frame inside a spare piece of AN 10 fuel line to insulate it     drinks
Jack
