October 06, 2008, 10:30:06 PM
| | |-+  69 GTS Rear Brake Help
Author Topic: 69 GTS Rear Brake Help  (Read 377 times)
xssive
« on: July 01, 2007, 04:50:29 PM »
I'm rebuilding the 8 3/4 from my 69 Doge Dart GTS.   The car is an original 383, 4-speed car and has 10" drums on the rear.  I've been looking around and cannot find a listing for these drums and no one seems to have a listing.  Does anyone know if these are the correct drums (10" vs. 9") and, if the 10" drums are correct, have a lead on where I might be able to purchase new ones.  I've looked at Layson's and YearOne and don't see a listing.  Any info is greatly appreciated!
Thanks, Vince
Re: 69 GTS Rear Brake Help
« Reply #1 on: July 01, 2007, 05:58:53 PM »
i bought my drums at the auto parts store,the trick is to ask for drums for a 71 satellite.
http://www.partsamerica.com/productdetail.aspx?MfrCode=WE1&MfrPartNumber=YH140182&PartType=222&PTSet=A
xssive
« Reply #2 on: July 01, 2007, 10:38:26 PM »
West,
Thank you for the response.  I'm thinking a 71 would be a 4.5" bolt pattern and I'm looking to keep the car as original as I can so, I'd like to stick to the 4" bolt pattern.  I'm thinking drums for 69 Coronet might also fit.
« Reply #3 on: July 01, 2007, 10:53:51 PM »
There is no b-body that can provide the correct drums for your car. They are small bolt pattern 10x1-3/4". They can be difficult to find, though. The last set I bought was around 2001 from a local parts house that carries a few oddball things as well as the entire CarQuest line. The good news is that the same drum was used on ALL V-8 a-bodies from 64-72.
« Reply #4 on: July 02, 2007, 12:26:08 AM »
i assumed because you had 10" drums that you had the large pattern too.
Dono
Want what you have..........
« Reply #5 on: July 02, 2007, 09:43:31 AM »
If you swap over to the 4.5" on five bolt swap everything over to the 89 dakota.  It all works so so nice and easy to get parts.
« Reply #6 on: July 02, 2007, 09:44:58 AM »
Watch ebay - you'll find a drum on there.
408 dart
« Reply #7 on: July 04, 2007, 11:13:19 PM »
i want to change to bbp, what all do i need from the 89 dakota
xssive
« Reply #8 on: July 06, 2007, 07:04:26 PM »
Thank to all who responded with information!   I was able to locate a set of drums for my GTS.   They are Wagner part # BD60123.   Kudos to Brandywine Auto Parts in Concordville, PA!
