December 01, 2008, 10:53:52 PM
| | |-+  upper control arm spacers
Author Topic: upper control arm spacers  (Read 200 times)
jackie
« on: July 02, 2007, 01:44:57 PM »
bill, i just my new arms in place. the right side fit fine. on the left side , i installed the thick spacer in the front, small one to the rear. on the back side of the arm, i had to put the short spacer in the front and the thick one to the rear. is this ok?? thanks.
Bill_Reilly
Administrator
White Haven, PA
Re: upper control arm spacers
« Reply #1 on: July 02, 2007, 04:14:19 PM »
Well, it is ok, everything will work and adjust fine that way, but I'd tweak things a bit to make them the same. The exact distance is 7.5" center to center on the a-arm tubes, which work out to the perfect width with the stock mounts, however some mounts are bent a little just due to tightening the stock bushings over their lifetime.
I like to make everything even or I get mental, but it will work like it is....
jackie
« Reply #2 on: July 02, 2007, 04:55:16 PM »
ok, i am going to look and measure some more , but the only part that looks likes i could tweak is the a arm itself..but i will measure again, and see what i come up with.. thanks
Bill_Reilly
Administrator
White Haven, PA
« Reply #3 on: July 02, 2007, 05:25:04 PM »
You could tweak the arm if it's the easier of the two. You could bend it into a pretzel and not hurt it, so it's no big deal structurally. Although if it's that much of a problem, you might want to just leave the spacers as they are and run it. Alignment is a piece of cake with the adjustable ends, so there's no point in beating yourself up if you don't have to....
