January 08, 2009, 10:44:54 PM
| | |-+  Is it easier just to change these damn left thread lugs?
Author Topic: Is it easier just to change these damn left thread lugs?  (Read 387 times)
ValiantOne
Western MD
« on: July 04, 2007, 10:00:52 AM »
Hey All,
With my new rims swap, I want to put some solid chrome plated lug nuts with on the car with a lock on each wheel. On the left side of the car they have the old left thread. Is it easier to replace the studs, than try to find left threaded lugs and locks?
If so, anyone know where I can order those studs?
Thanks much!
Chris E
Chris Evrard
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
kawazuki8097
New Cumberland PA
Re: Is it easier just to change these damn left thread lugs?
« Reply #1 on: July 04, 2007, 10:19:49 AM »
The resto places prob have the LH chrome lug nuts and prob want an arm and a leg for them as well. Check YO and see what they have. BTW - the lug nuts I had were all RH and went with the last set of LBP rallyes I shipped out.
The studs themselves are easy enough to swap out on the rear (beat them out, then use a lugnut and washer to pull them back in). The front ones are swaged (sp) into the drum / hub and are a bear to get out. I replaced a set in a '65 and we just peened them at the base to hold them into the hub.
I am vague about the reasoning behind the LH / RH threads. I am sure one of the guru's will have the correct explaination on why they used the diff threads.
Caledonia, ON Canada
« Reply #2 on: July 04, 2007, 11:21:51 AM »
The front studs DO NOT WANT TO COME OUT.  I filed the swaged over shoulder and pounded on mine for hours, only to bend one over.  I ended up buying another right hand thread hub at a swap meet and changing it over.  I now have two right hand hubs with new races, bearings and drums, if you can wait till I get off my a** and bolt up the disc brake kit sitting in my basement. \/][
GON_RACIN
Happiness is a warm gun.
« Reply #3 on: July 04, 2007, 12:00:43 PM »
I hate those left handed studs.   I'd just pull the hub and use a press to remove them, then promptly throw them in the nearest garbage can.  Some engineer was either hungover or had a sick sense of humor when he came up that idea.
Saint Paul, MN
« Reply #4 on: July 04, 2007, 03:54:29 PM »
They had some crazy rationale behind them coming loose with the differing rotational direction on the left side. I think someone slipped a little something in their brownies.
'67 Notchback- 12.85 @ 109mph
« Reply #5 on: July 04, 2007, 04:04:05 PM »
Replace them with right hand. There's no problem with the disc brake rotors/hubs getting the studs out, but the front drums I've dealt with were swaged over and would have to be cut or ground down to be able to get them out.
« Reply #6 on: July 04, 2007, 04:28:09 PM »
i would replace them with the right hand, but imo, the lug locks are stupid- many people have the key for them, they are pretty universal- if someone  really wants the rims, they will take them, my friend just got his complex, locking hubcaps stolen off his buick- usually they end up rusting on easier than regular lug nuts and then you will lose the key or break it
bbscamp
Ehm.....B5 Blue am I?
« Reply #7 on: July 04, 2007, 05:07:54 PM »
for front drums with pressed in studs, you need a hydraulic press.  There is a special press tool just for studs.  It supports the hub underneath, directly around the stud area.  Then a ram (~ 2" dia.) gets pushed down on the end of the stud to drive it out.   Once they are all out, then the drum can be seperated from the hub.   If you don't use the special tool, you will bend the drum at the hub.  If you switch one stud at a time, you won't even have to cut the drum.  When reinstalling the studs, the same tool is used.  The studs are pressed into the hub. Then (step 2 here)...the same tool is used, except the ram tool has a hole in the end, and it has the end ground down to a taper.  The stud goes into the hole, and the taper part pushes on the stud shoulder, speading it out to lock the drum on the hub.
Best thing to do?   go to a brake shop that can swap drums on your hub.  They will have the press and the tooling.  $6 for studs....a few $$ to press them in.  Go all RH thread.
wrflyer
« Reply #8 on: July 04, 2007, 08:56:08 PM »
  Do you really need locks? I have them and every time I have taken the wheel off I think why! .I never park it outside overight,never go to the movies and leave it out in the dark for hours, never leave it anywhere where someone would steal the wheel before the whole car.
ValiantOne
Western MD
« Reply #9 on: July 05, 2007, 08:57:58 AM »
Maybe I am just paranoid on the locking lugs. When I was a teenager I worked at a local tire shop for a year or so. Saw lots of stolen rims, tires/rims, etc.
The sucky thing is that I plan on doing a disk brake swap eventually, so I will be half way to my right hand threads already. But in the meantime I hate looking at those ugly open ended lug nuts!
So Year One would have the studs?
Chris Evrard
kawazuki8097
New Cumberland PA
« Reply #10 on: July 05, 2007, 09:15:11 AM »
Your local Advance, Autozone, Schlep Boyz or NAPA should be able to get the studs easily enough. I do not know if they are 'correct' or not, but I got a set of chrome lugnuts at Pep Boys one time they looked good on the steelies I had on my '67. YO would have the 'correct' ones, I'm sure.
« Reply #11 on: July 05, 2007, 06:06:07 PM »
Next time you are up my way either drive the car here or bring the front drum and I'll swap em out for you, bring the new stud with you ... the fronts are a pain but I made a jig to do them in my press ... duster
« Reply #12 on: July 05, 2007, 06:37:45 PM »
It was the 60's, but at that time, they were just smoking the stuff, not baking brownies.  !nanr
I would get rid of the studs. The rear axles are easy, the fronts are going to be a bear.  Frustrated
kawazuki8097
New Cumberland PA
« Reply #13 on: July 05, 2007, 06:59:25 PM »
Chris - ROAD TRIP!  Stop by and pick me up on the way.  Grin
« Reply #14 on: July 05, 2007, 07:33:21 PM »
The more the merrier ...  duster
nightrider
Duster Buster
« Reply #15 on: July 06, 2007, 09:48:22 AM »
Why does everyone have problems getting these out having to use a press? You're all not using a big enough hammer!!!!!!!  hammer
