January 08, 2009, 11:37:20 PM
| | |-+  Is a ballast needed if you run a MSD 6A box
Author Topic: Is a ballast needed if you run a MSD 6A box  (Read 290 times)
440darting
« on: July 05, 2007, 02:36:35 PM »
I am going to be running a Moper Performance electronic distributor and a MSD 6AL ignition box, is a ballast resistor needed , I was told no, only a good coil is the only other compentent needed for the ignition, is this correct
instrument
Re: Is a ballast needed if you run a MSD 6A box
« Reply #1 on: July 05, 2007, 02:44:32 PM »
NO it's not needed..... Just take the wires and twist them together. the box will control the rest..yes on the good coil...
« Reply #2 on: July 05, 2007, 06:07:38 PM »
 agree agree agree agree
Use the blaster 2 coil and get rid of the ballast resistor
