Topic: lower ball joint for big bolt conversion (Read 550 times)
roadrunnerreds
what ball joint did you use for converting to big bolt pattern wheels.i used 73 -76 lower ball joints and the steering did not turn as far so i ground off some of the stops.Brads
fstfish66
i used the 76 dart upper control arms,,,they have the big ball joints,,and i used the orignal 66 lower control arms,,and i used the lower ball joints that go to the 76 disc spindle,,,,,turns fine,,,
1966 barracuda blown 340 4 speed tubbed 33x22 1940 dodge street rod hemi with A/C 2002 cummins ram dailey driver
340fyd
Same here. Lee
Lee [img]http://www.moparpics.com/albums/Moparlees-64-Valiant/IMG_0228.sized.jpg/img]
375InStroke
 My steering box stops before it reaches the stops on the suspension.
fstfish66
both directions   if not both directions,, you may not have the pit man arm centered on the spline,, there is a notch on the spline and one the steering box,,..if problem is in both directions,,, i gues it would depend how much it stops turning short of the stops,,,,
