Topic: leaf spring rubbing gas tank (Read 226 times)
65rbdodge
i`ve already clearenced it with a hammer but it still rubs. can i loosen the straps and slide it over just a little? is there any other way?
 65 coronet 440/4 speed/9.75 71 dart custom 4 door 400/727/8.75 03 dakota 239/5 speed/8.25
Dono
This is after relocating the leafs in under the frame right? It was so close for my likings that I took the tank out and went to a fuel cell. There is nere no way you can get the 3" exhaust pipes to make it out the back with out hanging way down.
Don.
65rbdodge
yes, the springs are moved in. i dont have a full exhaust so i dodged that bullet.
do you have new bushings in the front and rear of the springs?
JohnnyfromChicago
i had the same problem after moving the leafs in - I wasy able to slide the tank over a little and hammered the tank a little.
