January 08, 2009, 10:14:17 PM
| | |-+  Death To The Spot Weld Cutter
Author Topic: Death To The Spot Weld Cutter  (Read 659 times)
sperrydan
I live for Mopar and my Ruth
« on: July 10, 2007, 01:57:23 AM »
I just got my spot weld cutter from eastwood and it was cutting great. But 5 Holes in the peace of crap brakes all the teeth off and cracks so i cant turn it over and use the other side explode. I paid 20$ plus shipping for this junk cutter. It cut good but the quality is bad. Its the 2 headed cutter that you can turn the head over. Its from eastwood.
Can someone help me with a good spot weld cutter that will not fall apart after a few holes.
Re: Death To The Spot Weld Cutter
« Reply #1 on: July 10, 2007, 02:26:09 AM »
Blair makes great cutting tools.
« Reply #2 on: July 10, 2007, 10:44:24 AM »
Call Eastwood, they will replace it for you or give you a credit.
BIG DOG
« Reply #3 on: July 10, 2007, 05:09:40 PM »
Yes probably a bad one .I bet it cracked then broke off the teeth.I have a $20 one and it has cut alot of holes close to 100 I bet and it's just getting on it last legs now.
« Reply #4 on: July 10, 2007, 05:15:21 PM »
Eastwood should be good for it- i have heard that cornwell tools make a pretty good one
« Reply #5 on: July 10, 2007, 08:08:53 PM »
Most any automotive paint store will have spot weld cutters in stock.  I tend to stick with the Blair brand, they are all fragile in nature ... meaning if you twist it or catch and edge it will break.  I always start by center punching the weld I am drilling out then hit it with the cutter ... just my 2 cents .... duster
73swinger
Blackstock, Ontario
« Reply #6 on: July 10, 2007, 08:55:56 PM »
try running it a little slower and use some oil
« Reply #7 on: July 10, 2007, 09:30:37 PM »
i use a drill cut at a shallow angle that is much larger than the spot to be removed.
if the part that is being removed is getting scrapped i use a die grinder with a three inch diameter disc that is 1/4" thick and just grind the spot/nugget.
takes a bit of practice and is noisy and smokey.
then there is the plasma cutter were you just cut a tiny little hole so the nugget drops out.
the shallow bit is the best though.
i know what you mean about the 20$ cutter desintigrating, pretty hard to go easy when you have a 100 or so spots waiting for some love.
then a thin chisle or gasket scraper to shear off what is hanging on between the panels.
motorhead446
« Reply #8 on: July 13, 2007, 11:33:51 PM »
I bought mine from snapon, about $25, he replaces it when it breaks. I get 75-125 cuts before it bbreaks.
automan63
« Reply #9 on: July 13, 2007, 11:48:48 PM »
try these guys
http://www.dentfix.com/viewItem.asp?idProduct=66&item=DF-1680T_8.0MM_HSCO_Titanium_Spot_Weld_Drill_Bit
I actually use these drills made for Boron steel now instead of the Titanium ones but I use em everyday so the $$ is worth it to me.
http://www.dentfix.com/viewItem.asp?idProduct=89&item=DF-1690_Boron_Killer_(STC)_Spot_Weld_Drill_Bit_for_UHSS_Steel
I use the Boron cutting bits in this. it's like a hand held drill press, from the blus collar to the drill tip moves out to meet the sheetmetal under air pressure while the drill spins. It's pissa.
http://www.dentfix.com/viewItem.asp?idProduct=21&item=DF-15_Spot_Annihilator_Spot_Weld_Drill
« Reply #10 on: July 14, 2007, 10:19:12 AM »
I think the big issue with spot cutters and making them last longer is:
1. They have to be perfectly level.
2. They have to be bigger that the welded spot itself.
« Reply #11 on: July 14, 2007, 10:21:46 AM »
try these guys
OMG! That is so cool, I want it just becuase of the name "Spitznagel Spot Annihilator Spot Weld Drill."   hammer lol  \/][  lol bash Cheers  !nanr  Grin
CudaDon65
« Reply #12 on: July 14, 2007, 11:13:09 AM »
BB_cuda
« Reply #13 on: July 20, 2007, 12:46:28 PM »
I have always used the Blair type with no issue. Well, I say no issue. When first starting to use them, I used plain ole SAE 30 oil and would not too many cuts.  I switched to cutting oil and low get the 80 to 100 the other folks are talking about without issue. I used it for creating plug weld holes for welding in new floor boards withsame cutting oil. Worked great but 3/8" holes were too big so i reduced to 0.25" holes with drill bit. Less grinding due to shorter mound.
For me, the cuting oil was the key. I had to cut a 3" hole in some sheet metal using a hole saw. No issue with the right oil.
375InStroke
« Reply #14 on: July 20, 2007, 06:07:33 PM »
Most people spin their drill motor too fast when drilling hard metals like steel.  You are cutting the metal, not grinding it.
BIG DOG
« Reply #15 on: July 23, 2007, 09:48:23 PM »
Very true I was using mine in a rechargable drill on slow speed made a lot of cuts without a problem...no lube .Then one day both of my batteries ended up dead and I went to my other drill which is faster the variable is hard to control.Wasn't so good for the cutter seemed to break off the teeth much easier .
