January 08, 2009, 08:46:45 PM
| | |-+  traction ?
Author Topic: traction ?  (Read 520 times)
mr.318
traction ?
« on: July 11, 2007, 08:05:05 PM »
where do you clamp the rearsprings?i did asearch come up with nothing i'm useing airshocks and after searching about them seems like alot of mixed opions there, i have a set of used stock shocks would they be better with anything over 40lbs. it spins less it wheelhops don't race much but when i do i'd like some traction i'm broke right now just won't to do some lowbuck stuff to help my traction there's gotta be some lowbuck tech i posted this on some other sites all they won't to do is make rude remarks about my airshocks
jwmotors
Re: traction ?
« Reply #1 on: July 11, 2007, 08:48:54 PM »
You clamp the front half of the springs . Clamp each leaf to the other out near the end . What you are doing is making the front half of the spring solid . which might help elminate the wheel hop .
mr.318
Re: traction ?
« Reply #2 on: July 11, 2007, 10:09:44 PM »
thanks thats what i thought just wasn't sure
55robert@comcast.net
Re: traction ?
« Reply #3 on: July 12, 2007, 01:26:51 AM »
use at least 1/2" bar stock and grade 8 bolts and tighten the snot out of them.
67Dart383
Re: traction ?
« Reply #4 on: July 12, 2007, 12:21:39 PM »
whats your set-up. 60 fts and are you running slicks or streetires?
67 Dart 383 MP590, Crane 1.6 R/R, headers, 906, 850 MIghty Demon, Performer RPM, 3inch exhausts, 727 R/M, 9.5 PTC 4500 flash stall w/ 2800 brake stall, 8 3/4 rear with P/T 4.30, on MT ET St Rad 11.71@114mph
mr.318
Re: traction ?
« Reply #5 on: July 12, 2007, 01:26:56 PM »
it's a 71 swinger little 318 bored 40 zerodecked kb167 pistons 268 cam balanced 355 s.g. 904 trans. 202 valves 360 heads 215-60-14 street tires all we have is a 1/8 mile track my best time is 8.80 2.264@ 60ft. 85 mph with a lot of wheelspin
67Dart383
Re: traction ?
« Reply #6 on: July 12, 2007, 02:07:17 PM »
This is the best run we have had so far on 225 60/15 B/F Goodwrench Radial TA street tires. We still have more left in the engine.
When I leave the line i don't hit it hard off the line, I just squeeze it off the line gently but quickly, then I just nail it, and it works everytime. If I do it quick enough I can get a even quicker 60ft time and faster E/T.  IT just take practice.   383KIDD
4th run the Fastest Run Ever still on the same street tires
r/t .179
60ft 1.874
1/8 7.921 mph 88.74
1/4 12.373 @ 109.73
mr.318
Re: traction ?
« Reply #7 on: July 12, 2007, 02:29:12 PM »
yea i'm gonna have to try launching differnt i've got a set of 255-60-15's but haven't tried to put em on yet they look to big ? i was reading a post yesterday saying your running airshocks to,thats a nice set up in your dart it would run in the 7's easy but i like what your doing seeing how fast you can go with street tires you know you got it when you get ready you'll use it
67Dart383
Re: traction ?
« Reply #8 on: July 12, 2007, 02:52:45 PM »
We still have more in the car we can get out of it.    We are looking for some more taller and a little wider street tires and we found some 255 60/15 Firestone firehawk Indy 500, which are some good sticky street tires, but they are becoming harder to find, we can get some but it will cost $280 then we have to pay to get them mounted and balanced, we might as well buy some drag radials, but we want to stay true street. We have a second choice which are some Yokohoma Avid S/T which are second best to the firestones, we may end up getting those. The taller tires will help gain more traction  off the line and reduce rpms on the big end hopefully creating faster  mph and lower E/T which might put us in the  11's with street tires. I believe I can do it.
383KIdd
mrbill00
Middle Georgia
Re: traction ?
« Reply #9 on: July 12, 2007, 06:56:09 PM »
check "the tire rack"              http://www.tirerack.com/
they have the 255/60/15 (27.1" tall) in the firestone firehawk indy500 for $78.00 each plus shipping ($12-$15)
whcih isn't too bad.  then all you do is have them mounted/balanced like you were going to do any way
and you saved 80 bucks..they also have a "specs" chart which tells wide, higth, rim size, etc
as time goes on you'll work your way towards different shock/suspension-engine combinations setups that will
change the tire requirements again
dartracer
Strasburg CO.
Re: traction ?
« Reply #10 on: July 12, 2007, 07:03:51 PM »
Where is the snubber at? Should be about 1/2 to 3/4 of an inch away from the body. Try it, the car might like it.
67Dart383
Re: traction ?
« Reply #11 on: July 12, 2007, 09:32:51 PM »
Thanks MrBill00, but tirerack is out of stk and don't know if they will get any more in . This tire is no longer being made!
Re: traction ?
« Reply #12 on: July 12, 2007, 11:23:22 PM »
i have the avids on my fronts right now and if they grip going strait in the rear anything like how well they grip in the front going around corners, then they will rock
the avids you can get 60k miles out of Wink 4 speed with proper rotation and they rule in the rain
the Firestone just look too much like a mileage tire to get any grip out of them
74' DART
Work in Progress
demonbbmopar@yahoo.com
Re: traction ?
« Reply #13 on: July 12, 2007, 11:32:09 PM »
I work for firestone in FLA and we still have some indy 500's. I don't know how good of a traction tire they would be though. I also like what u are doing with running street tires , but i think that if u are going to spend a few hundred u should propably put on some street radials like bfg or i have a friend who had real good luck with MT ET streets. those things hooked up good even on some streets! Good luck guys J.R.
mr.318
Re: traction ?
« Reply #14 on: July 19, 2007, 12:46:01 AM »
okay i got my springs clamped today let the air in the shocks down to 30lbs. no wheelhop but still major wheelspin it sits reallow with the air @30 in the shocks but still real stiff in the back so i'm wandering if i put stock shocks in the back will it transfer weight to the rear and help traction ? anybody think it'll help the 255-15's won't fit you couldn't put a peice of paper between the tires and leafs there 8inc rims offset must be wrong atleast i didn't buy em
67Dart383
Re: traction ?
« Reply #15 on: July 19, 2007, 01:25:22 PM »
Thats improvement.
When you go racing again, tyr not to give it all the power right off the bat. Let the power come on gradually that way ut will allow your tires to try to hook once it gets going.
Everytime I slap it off the line reall hard it goes up in smoke. So what I do is just ease into the throttle quickly but not quickly where you start spinning.
Also on your tires and rims combo you put your 255 60/15's on and were they rubbing the leaf springs and the inner part of the fender lip.
We should be getting our Firestone Firehawk Indy 500 tires today or tomorow, we are going to put them on and take the car to our local 1/8 mile track in Mississippi.
Another way to try to hook better is try not to do a big burnout, just a slight burnout because they heat up quickly. Basically just clean them off.
Our springs are clamped just in two areas, i think they are stock locations on the springs.
383Kidd
mr.318
Re: traction ?
« Reply #16 on: July 19, 2007, 04:39:27 PM »
the tires were rubbing the leafs i think the fender lip cleared but was close yea i'm going back to yhe track this sunday test n tune i got 2 stock 15 inch rims today from a dipomat i wander what size tire i could put on em that would fit on my car i jut don't think them 14 s are doing justis 67dart how much air do you run in your shocks
67Dart383
Re: traction ?
« Reply #17 on: July 20, 2007, 12:56:05 PM »
25lbs in rear air shocks ( single  fill valve goes to both shocks)
