August 28, 2008, 08:42:57 PM
| | |-+  Slider vs. Pin calipers
Author Topic: Slider vs. Pin calipers  (Read 218 times)
ValiantOne
Western MD
« on: July 13, 2007, 01:42:50 PM »
In a nutshell what makes the slider caliper more desirable than the pin type?
I have a set of pin type and I am wondering if it is worth it to swap for the sliders.
Thanks!
C
Chris Evrard
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
Re: Slider vs. Pin calipers
« Reply #1 on: July 13, 2007, 03:09:43 PM »
here is my experience
everyone said that the sliders were better, so i got the sliders for my car, mostly because its has less parts and is simpler and i believe the calipers are more available and cheaper
realistically they work about equal
last fall after i put about 2,000 miles on the new brake i pull them apart to check it over and found hot that there was a small pebble that worked its way into the machined way under the hold down clip- it marred everything up- so i pulled it apart and filed the machined way down nice and flat again-
i haven't had problems since
if i were to do it again i would use a pin type for alittle more smoothness and more containment
DartKnight
« Reply #2 on: July 13, 2007, 06:43:41 PM »
I've heard that the parts for the pin-type are harder to find. I prefer them to sliders simply because I've owned more cars that had them; I could do a pad change on both sides in about 10 minutes time... Smiley
Jason
« Reply #3 on: July 13, 2007, 08:56:14 PM »
Functionally they are about equal. The pin-type parts are more expensive and harder to find. The pin-type also never came on an a-body.
ValiantOne
Western MD
« Reply #4 on: July 13, 2007, 09:56:55 PM »
Ahh, ok. So if I have 'em already (pulled 'em off one of my Cordobas) There is no reason not to use 'em.
DartKnight I agree with you there, I used to change those puppies so quick it wasn't funny. The only downer was I broke a couple of pins off in the assembly tryin' to get them off once or twice.
Thanks Guys!
Chris Evrard
« Reply #5 on: July 13, 2007, 11:22:50 PM »
as long as you grease them every 10k imles or so, they will be no problem to dissasemble
DartKnight
« Reply #6 on: July 14, 2007, 12:47:16 AM »
Yep, you have to keep them lubed up or they're done. I used to have a box full of them; I picked up a few every time I went to the junkyard, just in case...
Jason
