December 05, 2008, 12:33:42 PM
| |-+  Early A-bodies
| | |-+  Differnces between 66 and earlier vs. 67 and later A Body
Author Topic: Differnces between 66 and earlier vs. 67 and later A Body  (Read 2007 times)
ValiantOne
Western MD
« on: July 13, 2007, 10:25:20 PM »
Hey Guys,
If everything goes according to plan, my new 66 Valiant should come home tomorrow. If memory server me correctly, the width of the engine bay is more narrow than the later A bodies. Correct?
I am guessing that retrofitting a SB engine wouldn't be such a big deal, but is it that much harder to wedge a BB in there?
Thanks guys,
Chris
Chris Evrard
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
bbscamp
Ehm.....B5 Blue am I?
Re: Differnces between 66 and earlier vs. 67 and later A Body
« Reply #1 on: July 13, 2007, 11:02:36 PM »
The 66 is the narrow engine bay.  SB is a much easier fit.  Exh. is always the fun part.  The easiest solution for a mild to mid-built 318 is the 273 SB Cast Iron manifolds.  I'm using them on my 318 / eddy intake & carb.  The flow well, but not good enough for a built 340 or 360.   If you go that route....I have another set kicking around.....
The pass. side is pretty easy, but you'll need the offset oil filter adapter.  The drivers side is pretty neat.  Its got a "C" shape that routes right around the steering column.  A real problem solver for the SBs.
Oh yeah...BB?  you can make anything fit...but its tougher.
abodyjoe
South Jersey...
abodyjoe
« Reply #2 on: July 14, 2007, 04:16:04 AM »
a big block is pretty easy to bolt in. infact i think a big block is easier to work on in those cars becays the dist. is up front and away from the firewall making the trans bolts easier to get to....    the biggest problem fo a big block in an early -A is no one makes headders....      a small block is an easy swap..  like mike said you can run the factory 273 manifolds, i've seen the 73 style 340 manifolds used on those cars and for headders you have the spitfires,tti and dougs that fit it along with hooker and i think headman...
AZ69DART
« Reply #3 on: July 14, 2007, 01:53:10 PM »
Nice thing about swapping from a "Leaning Tower of Power" to a small block in a 63-66 A-body is the K-members are the same. All you have to do is locate the V8 mount brackets...which isnt that hard to do. The lack of clearance kind of limits things. I have to run fenderwell headers on my 63, which I dont mind because its race only. But when I built the car, under chassis headers werent even available yet.
1968 Barracuda fastback
360/A833/3.55
11.25:1, 292/509, Edelbrock RPM heads, Weiand intake, 800 DP, H-beam rods, windage tray, Hays clutch, scattershield, 8 3/4 (489 case), 3.91 sure-grip
1974 Plymouth Satellite pursuit
360/904/3.21 SG
2001 Durango SLT (daily driver)
4.7/auto/3.92/ 2WD
CudaDon65
« Reply #4 on: July 14, 2007, 02:56:22 PM »
Chris I'm going with a sb for my 65 barracuda. On Bill's other sight (RMS) in the gallery there are pics of a 440 in a early a-body with headers. That car has Bill's alterk installed but you can see how a bb would look and fit. In the pics the headers are Hooker super comps. Not sure they will work but the Hooker comps. will.
LILBLUE65
« Reply #5 on: July 14, 2007, 05:43:17 PM »
Here is a 440 in my old 63 with under chassis headers.  Rob
AZ69DART
« Reply #6 on: July 14, 2007, 05:53:10 PM »
WOW! That look pretty snug  Shocked
360/A833/3.55
360/904/3.21 SG
4.7/auto/3.92/ 2WD
LILBLUE65
« Reply #7 on: July 14, 2007, 10:47:55 PM »
Yup
abodyjoe
South Jersey...
abodyjoe
« Reply #8 on: July 15, 2007, 04:27:50 AM »
heres my 64 valiant with a 440 in it...    i'll have to build another one day..
ValiantOne
Western MD
« Reply #9 on: July 15, 2007, 05:57:16 PM »
thank you guys:)
If I ever get the right headers for my 68 Val, I will have a set of 273 manifolds laying around that I could use on the 66. Thanks bbscamp. Those 273 manifolds look really small though. I saw the sticky thread on the spitfires (I think it was the spitfires) and that looks like  a good route too.
For now I plan on finding a wiring harness for the car and connecting the /6 back up. There will be a lot of metal work in the floor pans and rear quarters too. As I have never done any serious sheet metal work, this will be a serious learning experience for me.
Thanks again!
Chris
Chris Evrard
340fyd
« Reply #10 on: July 16, 2007, 09:17:03 AM »
I couldn't find that picture in that gallery.
Lee
Lee
bbscamp
« Reply #11 on: July 16, 2007, 06:02:10 PM »
Joe  Blah Blah Blah    Don't you know you can't put a RB motor in an early A?      LOL
abodyjoe
South Jersey...
abodyjoe
« Reply #12 on: July 16, 2007, 06:39:08 PM »
  you know i have heard that somewhere before...lol.
CudaDon65
« Reply #13 on: July 17, 2007, 09:10:04 AM »
Lee
Lee, did you go to Bill's other sight (RMS.com)? in the gallery bottom of page right side. Hope this helps.
bigblockhead
« Reply #14 on: July 24, 2008, 10:09:36 PM »
 hey joe,  did you build those headers from scratch or modify an exsisting set.  those are the COOLEST HEADERS I'VE EVER SEEN!!
brickman
« Reply #15 on: July 27, 2008, 10:27:23 AM »
Man that is tight, I am wanting a early ragtop to put my 451 low deck in.  I am thinking headers will be a problem to get huh?
abodyjoe
South Jersey...
abodyjoe
« Reply #16 on: July 27, 2008, 11:11:04 AM »
 a local shop built them for me from scratch.
WAGGIN
« Reply #17 on: September 23, 2008, 11:47:09 PM »
The 68 valiant 273 manifolds are not the ones you need,you might be able to use them but you need 64 to 66 drivers side manifold,when you see one you will know why,good luck on your build. motorinstall
thank you guys:)
Thanks again!
Chris
pishta
« Reply #18 on: October 06, 2008, 12:36:19 AM »
Maybe from me, that is why I went with a 451 B  Wink
